Author Topic: Does a keycap with this kind of thickness exist?  (Read 5823 times)
Offline Bottles
« on: Thu, 30 May 2013, 21:05:14 »
This is supposed to be the keycap im looking for cut in half where the grey area would be solid.
Preferably they would be blank.
Re: Does a keycap with this kind of thickness exist?
« Reply #1 on: Thu, 30 May 2013, 21:06:46 »
None that are readily available.
Offline Turkishrambo
« Reply #2 on: Thu, 30 May 2013, 21:12:51 »
Haha why would u need caps that thick? :P
Youd prob need stiffer springs to make up for the weight of them..
« Reply #3 on: Fri, 31 May 2013, 12:22:21 »
Turn your keycaps over and pour a quarter of a spoonful of concrete in them.
- D Trump 2026-10-24
Offline Tym
« Reply #4 on: Fri, 31 May 2013, 12:34:20 »
Clacks are like that; or at least mine is (and i only have one :()
« Reply #5 on: Fri, 31 May 2013, 13:37:03 »
Once upon a time, I saw a picture in this forum of keycaps that some Chinese guy (?) had filled with Sculpey (or other polymer clay) in the empty space above the key stem.
However, that would only work with PBT keys. ABS starts warping at a temperature lower than what is needed for curing Sculpey. Sculpey is also not adhesive when cured - it would be held with friction only.
Btw, Cherry profile keys on the home row -- the lowest keys -- have very little extra space, even the thin-walled PBT keys.
Offline strafe
    • Strafe's Blog
« Reply #6 on: Fri, 31 May 2013, 20:32:17 »
I guess you could put some blu-tack in them to figure out how much extra weight you can add to each row of keys
Freebird WKL (Blacks Clear-Tops), iKBC F-104 (Blacks) and more!
« Reply #7 on: Fri, 31 May 2013, 22:26:42 »
Boost's superhero caps are perhaps the thickest I've seen.
Offline Bottles
« Reply #8 on: Sat, 01 June 2013, 10:39:36 »
Thanks! I found a bunch of pics of what Im looking for in this album. http://imgur.com/a/ZRPcb/layout/blog
Specifically this picture. The Leftmost is ideally the key cap profile that I want.
Im assuming its impossible for CC to make me some sort of blanks either with his plastic or with ABS or PBT so the search continues.
« Reply #9 on: Sat, 01 June 2013, 10:49:52 »
well that was an alps protoype, are you wanting alps keys or mx keys?
Offline Bottles
« Reply #10 on: Sat, 01 June 2013, 11:43:19 »
MX keys ideally. The only thing I was referencing in that image was the thickness of the top of the cap.
Offline elttaboi
« Reply #11 on: Sat, 01 June 2013, 13:13:51 »
clickclacks are that thick, but you can't just buy those :P
Best suggestion is to get imsto thick pbt keys if you want weight.
Offline tricheboars
  • Keyboards are Important!
« Reply #12 on: Wed, 05 June 2013, 11:39:31 »
awww snap. Ripster pics.
Offline Turbo Slaab
« Reply #13 on: Wed, 05 June 2013, 11:47:58 »
Just find a whole bunch of CC clusters.
Looking for CC's!
