Author Topic: NMB keyboard  (Read 2039 times)
Offline Magna224
NMB keyboard
« on: Sun, 02 June 2013, 14:50:22 »
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Offline elttaboi
Re: NMB keyboard
« Reply #1 on: Sun, 02 June 2013, 16:49:09 »
this is membrane version right?
Re: NMB keyboard
« Reply #2 on: Sun, 02 June 2013, 22:32:00 »
I think the RT101 might have "space invaders".
Auction is now over, sold for $10. If I Gh'er got it, I'd like to hear the impressions.
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
Re: NMB keyboard
« Reply #3 on: Mon, 03 June 2013, 02:07:13 »
I think I bought something similar to this one with same fcc id. It turned out to be membrane, though better quality switches. good luck.
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Re: NMB keyboard
« Reply #4 on: Mon, 03 June 2013, 07:23:35 »
I have had RT101s that were plungers over domes.
- Oliver Willis 2026-08-01
Re: NMB keyboard
« Reply #5 on: Mon, 03 June 2013, 15:03:25 »
ah, looks like I may have been mistaken, then. That's what I get for conflating similar model numbers.
Offline Magna224
Re: NMB keyboard
« Reply #6 on: Mon, 03 June 2013, 15:29:10 »
I was under the impression all of the ones labeled HiTek were space invaders. I accidentally bought it though btw. I bid the starting price then nobody bid on it. Space invaders are pretty nice, similar to MX Blues from what I remember. Same feel but without that jig that MX blues have. Probably feels just like those jailhouse blues those guys were making.
Re: NMB keyboard
« Reply #7 on: Mon, 03 June 2013, 16:46:50 »
Please let us know. "Space Invaders" are very nice switches.
I think that the RT101 number was very common. I think I even had an AT&T branded board with that number.
