Author Topic: KBC Poker Function Layer  (Read 3673 times)
Offline PointyFox
« on: Sun, 02 June 2013, 16:58:55 »
Are there any KBC boards that allow me to easily use function keys 1-5 with only my left hand?  Like, can I reassign the Fn key to the left Windows key?
Offline PointyFox
Re: KBC Poker Function Layer
« Reply #1 on: Mon, 03 June 2013, 00:36:09 »
No?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Mon, 03 June 2013, 09:52:24 »
On first version Poker there is a dipswitch setting to make left win 2nd Fn key, so you can one hand it, though it feels akward to me to curl thumb underhand and reach for the 1-5 key.
Offline PointyFox
« Reply #3 on: Mon, 03 June 2013, 12:41:21 »
Thanks! Do you know if Poker 2 has the same switch? Also could I also do this with GH60? If I can, when is the GH60 going to be available?
Offline SmallFry
« Reply #4 on: Mon, 03 June 2013, 12:48:16 »
Here's the Poker II manual.
Offline PointyFox
« Reply #5 on: Mon, 03 June 2013, 12:55:49 »
So.. yes. Thanks. Are the switches easier to mod on the poker 1? I think poker 2 has a plate?
Offline SmallFry
« Reply #6 on: Mon, 03 June 2013, 13:02:12 »
The Poker II will need to be desoldered, yes.
Offline PointyFox
« Reply #7 on: Mon, 03 June 2013, 13:20:06 »
 I'm guessing the plate for Poker 2 doesn't allow for spring removal. If the Poker 1 doesn't need desoldering, where can I get  them?  :)
Offline SmallFry
« Reply #8 on: Mon, 03 June 2013, 13:21:35 »
I'm not sure on a Poker I source anymore, mostly secondhand. The GH60 will likely prompt a bunch of Poker I sales. The Poker II is available via Qtan and i3oiler, I believe though (i3oiler hasn't put them on TechKeys yet.)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #9 on: Mon, 03 June 2013, 13:27:39 »
The Poker 2 is also due to arrive at MechanicalKeyboards any day now.
Offline PointyFox
« Reply #10 on: Mon, 03 June 2013, 13:34:28 »
Any hope of green or clear switches?
Offline kernelpanic
« Reply #11 on: Mon, 03 June 2013, 13:37:38 »
qtan had only blue, brown, black and red.
« Reply #12 on: Mon, 03 June 2013, 13:43:05 »
Original ones weren't made with clear, white, green, grey... Due to trends I could see some limited II version with those choices maybe. Personally I prefer GH60 due to the physical layout choices though it can easily be a lot more involved and much more expensive than just buying a Poker II or used Poker, though I will be surprised if many of them are sold with cases.
