Author Topic: Can someone explain this ebay bidding?  (Read 3703 times)
Offline calavera
« on: Mon, 03 June 2013, 01:00:25 »
How is this one guy bidding continuously without getting outbid until the very end by the other guy? I thought ebay doesn't increase bids to your maximum set bid unless you're outbid by someone else?
Offline REVENGE
Re: Can someone explain this ebay bidding?
« Reply #1 on: Mon, 03 June 2013, 01:02:10 »
I don't think he's bidding, rather someone else is bidding and the second-price is getting updated.
Offline calavera
« Reply #2 on: Mon, 03 June 2013, 01:04:01 »
But if someone did bid and got instantly outbid shouldn't his username show up as well?
Offline okooko
  • afk.
« Reply #3 on: Mon, 03 June 2013, 01:05:18 »
im assuming the winner bid more than the other buyer (as he tried to increment his bids)
what ever the winner bid, it was 2.50 or more than the next highest.
winner could have put in like 12312312412 but yeah
Offline Michael
  • Formerly Bro Caps
« Reply #4 on: Mon, 03 June 2013, 01:05:34 »
When you set the max amount you are willing to spend, it will auto-outbid the person until they surpass the top price you bid.
« Reply #5 on: Mon, 03 June 2013, 01:05:57 »
Not the way it works. For example :
A sets max bid as $100
A is current highest bidder at $50
B sets max bid as $70
B's bid doesn't show up
A is now current highest bidder at $71 (70+increment)
1337
Offline okooko
  • afk.
« Reply #6 on: Mon, 03 June 2013, 01:06:45 »
yeah it does, so the s***2 guy got outbid by an earlier bid(which won the acution) and was logged each time he tried to increment it up
Offline calavera
« Reply #7 on: Mon, 03 June 2013, 01:18:53 »
1337
So the guy that got auto outbid doesn't show up at all.
I was talking about whoever got outbid by s***2.
« Reply #8 on: Mon, 03 June 2013, 01:20:35 »
If he/she gets instantly outbid by someone else's maximum bid that is already in place then yes it won't show up.
Offline insilica
  • Keyboard Geeza
« Reply #9 on: Mon, 03 June 2013, 06:49:38 »
Isn't there an option on ebay auctions "Show Autobid" or something. It should show you a full log of bids no matter how small the increment is.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline RabRhee
« Reply #10 on: Mon, 03 June 2013, 07:06:42 »
There is a "Show Automatic bids' option top right to show when eBay auto-bids and what amount. Look at the times to see the sequence. They could maybe add an option to sort by time so it would make a bit more sense. k***2 bid at 8:19 with at least $162.5, maybe 200 or 5000 for all we know.
Postal auctions work this way, where instead of bidding like a normal auction, you just set your maximum amount and you trust the auctioneer to bid as if you were in the room. Most auction houses allow this, but you are at the discretion of the auctioneer to trust them not to just stiff you for $1 below what you say your top bid will be.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
