Author Topic: The Living Power Supply Thread  (Read 3234 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« on: Mon, 03 June 2013, 10:21:16 »
I need a bench power supply. linear regulation, low ripple, 1 or 2 rails. should be able to do up to 30v 3-5A on one of the rails, fine and coarse voltage and current limiting, etc.
as usual i'm on a budget (a tiny one). suggestions?
mastech and rigol seem to be the leaders here. anyone use their benchtop supplies and have feedback?
Offline SmallFry
Re: The Living Power Supply Thread
« Reply #1 on: Mon, 03 June 2013, 10:24:27 »
I use a PSU from an old Desktop. I really should add a few petentiometers to a box and what not to make it a bit cleaner.
Offline mkawa
« Reply #2 on: Mon, 03 June 2013, 10:31:22 »
LINEAR (switching power supplies have a lot of high frequency noise)
Offline SmallFry
« Reply #3 on: Mon, 03 June 2013, 10:33:05 »
Ah, I never noticed in my applications much. :)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Mon, 03 June 2013, 10:34:36 »
My bench supply is from Electro Industries... 30v 3A, does what I need.  Got for free from a previous lab job, and have never been in the market.
What's your use case?  :)
Filco w/ Imsto thick PBT
Offline mkawa
« Reply #5 on: Mon, 03 June 2013, 10:39:00 »
right now, i need to power arm and atmel based dev boards. for that, switching is no problem. i also want to sink some serious power into heating filaments (switching again is no problem for that). BUT pretty soon i'm going to need to drive and test stepper and linear dc motors and noise is a big deal there, as i'll be doing error measurements. basically, it's going to be a real lab supply for research, so i need to minimize sources of noise. if there's a particularly nice modern switcher lab supply (some modern switchers have LESS ripple than older linear regulators) then please point me to it. (for example, check out the ripple and noise on some newer TDK-lambda supplies. they're switchers but you wouldn't know it from any measurement device that costs less than 2 grand)
Offline mkawa
« Reply #6 on: Sun, 09 June 2013, 18:11:04 »
i ended up buying this: http://www.amazon.com/Mastech-HY3005F-3Triple-Linear-Power-Supply/dp/B004ISD7T6/ref=sr_1_1?ie=UTF8&qid=1370819372&sr=8-1&keywords=lab+power+supply
it's a shockingly good deal. unsurprisingly, it doesn't put out quite as much power as advertised (in my copy, both rails top out at 4A @ 30v), and the inbuilt meters are not all that accurate, but it's beefy as **** and is incredibly stable.
