Author Topic: Offsite storage  (Read 8160 times)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
Offsite storage
« on: Fri, 25 July 2008, 11:31:42 »
I've been looking for a place to store files online and I found a few places that are cheap / free for a couple or a few GB of storage (which is plenty for me since it's all .doc files). I'm currently trying out Mozy while I'm waiting for an invite to Dropbox.
Does anyone use one of these services? If so, let me know what your experiences with are and which ones to avoid. The only thing I honestly care about is stability and Mac compatibility.
Offline bigpook
Offsite storage
« Reply #1 on: Fri, 25 July 2008, 12:04:27 »
This may be useful
http://www.rsync.net/
I don't use it though. But it integrates with the Mac OS.
rsync is a really cool tool, btw
Offline FunkTrooper
    • http://funktrooper.t35.com/
Offsite storage
« Reply #2 on: Fri, 25 July 2008, 13:28:15 »
how about using Gmail.  I know it's meant to be for email, but it seems that it's pretty good for remote storage too.
http://www.lockergnome.com/osx/2005/10/18/use-gmail-like-a-hard-drive-on-your-mac/
i've used something similar for Windows, and it worked really well.
Offline xsphat
  • Enlightened
Offsite storage
« Reply #3 on: Fri, 25 July 2008, 13:58:41 »
I've been doing the gmail thing for a while but it kind of isn't what I need it to be. Mozy is supposed to back up my links and my Writing achieve automatically every week, so I hope it works out the way they say it does.
But dropbox looks really cool. Does anyone use it?
Offline bigpook
Offsite storage
« Reply #4 on: Fri, 25 July 2008, 14:20:19 »
iMav gave me an invite for it awhile back but unfortunately, it doesn't work with linux. I was not able to use it.
Offline xsphat
  • Enlightened
Offsite storage
« Reply #5 on: Fri, 25 July 2008, 14:32:13 »
Well, if iMav happens to have another invite, I'd be glad to take it off his hands. Did you find out about charges even though it alienates Linux users?
Offline xsphat
  • Enlightened
Offsite storage
« Reply #6 on: Fri, 25 July 2008, 14:34:07 »
And let me point out that even though I don't use Linux, I think it's crap that there isn't more support for it, especially in light of it's growing user base (which is partly due to Vista blowing ass so bad).
Offline bigpook
Offsite storage
« Reply #7 on: Fri, 25 July 2008, 14:56:22 »
as a linux user you get used to it. but thats ok, that rsync.net site I sent you looks promising, but I haven't tried it. It supports all OS's too.
Offline iMav
  • geekhack creator/founder
Offsite storage
« Reply #8 on: Fri, 25 July 2008, 17:35:07 »
Offline JulienC
  • Esc Artist
Offsite storage
« Reply #9 on: Fri, 25 July 2008, 20:53:58 »
I tried box.net for the trial period, it's okay and they provide WebDAV access, so you can mount your online directory in your local directory tree using davfs on linux.
Quote from: iMav;6919
Check it.
Why did you use the Comic Sans font for this post ? My eyes are bleeding.
« Last Edit: Wed, 09 October 2013, 11:51:17 by JulienC »
HHKB
Offline xsphat
  • Enlightened
Offsite storage
« Reply #10 on: Fri, 25 July 2008, 22:13:57 »
Thanks for the invite iMav, I'll offer my invites here as well.
Offline xsphat
  • Enlightened
Offsite storage
« Reply #11 on: Sat, 26 July 2008, 01:40:17 »
Check this out:
Offline xsphat
  • Enlightened
Offsite storage
« Reply #12 on: Sat, 26 July 2008, 01:40:58 »
I signed up for the next beta in any case.
Offline iMav
Offsite storage
« Reply #13 on: Sat, 26 July 2008, 06:07:05 »
Quote from: JulienC;6920
Because I, specifically, wanted to annoy you.  ;)
I dunno, I was just goofing around with fonts that day.
Offline xsphat
  • Enlightened
Offsite storage
« Reply #14 on: Sat, 26 July 2008, 13:19:45 »
Offline karlito
    • http://altitudegame.com
Offsite storage
« Reply #15 on: Sun, 27 July 2008, 18:36:53 »
along these lines for those of you who are paranoid about the privacy of your data TrueCrypt is really awesome, I've been using it awhile.  It's very user friendly.
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
Offsite storage
« Reply #16 on: Sun, 27 July 2008, 19:31:57 »
Quote from: karlito;6964
I use TrueCrypt on a 100MB virtual volume to store sensitive data.  very easy to use.
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline G.A.Pster
Offsite storage
« Reply #17 on: Sat, 23 August 2008, 01:17:41 »
I’ve still got 56K so it’s an impossibility for me.
Offline ashort
  • Hoosier Daddy
Offsite storage
« Reply #18 on: Sat, 23 August 2008, 11:28:08 »
TrueCrypt isn't specifically for online storage, it's cross platform and allows you to encrypt files and volumes (even physical disks).  You choose how big you want your volume to be.
Andrew
Offline bigpook
Offsite storage
« Reply #19 on: Mon, 15 September 2008, 19:22:35 »
In case someone was wondering, dropbox now has a linux client.
