Author Topic: White on Dark Gray  (Read 4809 times)
Offline HoosTrax
White on Dark Gray
« on: Mon, 03 June 2013, 17:53:43 »
I'm looking to acquire a keyset that is white on dark gray. I think I've seen the Dolch keyset that's this color scheme and there are probably some clones of the original as well floating around. Are there any others that fit this description? Because I've seen one that's slightly different from Dolch, with centered lettering instead of left-offset.
Offline bazemk1979
Re: White on Dark Gray
« Reply #1 on: Mon, 03 June 2013, 20:20:03 »
 those are very hard to find, made by SP. there should be GB for DSA that kinda looks like that with Dolch colors, should be run by teamredline
Offline HoosTrax
« Reply #2 on: Mon, 03 June 2013, 20:42:52 »
Found it, thanks. Looks so good...dark gray never gets old.
Offline anhvu
« Reply #3 on: Tue, 04 June 2013, 18:11:53 »
The'yre for preorder over at origninative!
https://www.originativeco.com/dolch
Offline elttaboi
« Reply #4 on: Tue, 04 June 2013, 22:05:17 »
Offline UniClown
« Reply #5 on: Wed, 05 June 2013, 07:07:54 »
Would it be possible to join that GB even if I am from the US?
Offline tricheboars
  • Keyboards are Important!
« Reply #6 on: Wed, 05 June 2013, 11:37:15 »
i want those caps from that korean site. are they going to extend this to geekhack?
Offline HoosTrax
« Reply #7 on: Wed, 05 June 2013, 12:51:59 »
Having a hard time deciding whether to just preorder those Dolch clones, or wait for a possible Dolch-inspired DSA set group buy.
The giant legends on the DSA are a little...I don't know...
Offline bazemk1979
« Reply #8 on: Wed, 05 June 2013, 17:54:25 »
they are not clones..... they are the real deal, they are made by GMK, so did GMK made Dolch keycaps 20 years a go. Its the same company, same quality with small changes for better such as, 1.25 modifiers win and page keys are true factory DS, option for 7 and 5 size space bar, later down the road there will be more things complementing GMK sets for different layouts.
so that said these these are all original caps, made by the same company that used to make DS caps for Cherry boards. We already had GB for some modifiers, few things have gone wrong, but GMK comes trough and fixes the minor mistake, here is the tread, you can see that with this company any type of layout will be taken care of, offcourse it cost a tad bit higher than SP sets, but worth it 100%.  http://geekhack.org/index.php?topic=41017.0
Offline Aranair
  • Software Engineer @ PocketMath
    • Tech blog
« Reply #9 on: Wed, 05 June 2013, 20:19:48 »
Eh originative started another round of that? I remember they were out of stock for a while a week or two ago.
Present  : HHKB Pro 2 Type-S White | HHKB Pro 2 White Blank | Ergodox EZ
Past      :  Poker 2 Brown | Black Widow Ultimate Blue | Filco TKL Brown
Offline Aranair
    • Tech blog
White on Dark Gray
« Reply #10 on: Wed, 05 June 2013, 20:20:37 »
Edit: duplicate post:/
