Author Topic: best place for Cherry stabilisers - UK  (Read 3208 times)
Offline ShivaYash
« on: Mon, 03 June 2013, 18:30:25 »
Hello
I need one stabiliser - I am based in the UK.
Where should I go for this?
Many thanks,
SY
IBM Model M SSK, HHKB Pro 2 BT and Realforce 104U HiPro
Offline GeorgeK
Re: best place for Cherry stabilisers - UK
« Reply #1 on: Tue, 04 June 2013, 12:10:45 »
PCB Mount or plate mount?  Cherry not costar I presume?
Offline ShivaYash
« Reply #2 on: Tue, 04 June 2013, 13:24:31 »
Its for my FILCO so plate mounted...
« Reply #3 on: Tue, 04 June 2013, 13:38:53 »
You can't use cherry stabs on a filco. You want costar stabs which you can get from keyboard co
Offline ShivaYash
« Reply #4 on: Tue, 04 June 2013, 16:20:14 »
Thanks, I thought that, just trying to avoid Keyboard Co's crazy arse postal cost! £4.19 for a Jiffy Bag 1st class is a little steep, esp. when the item costs no more than a £1, tops.
