Author Topic: Sourcing new blue cherry switches...  (Read 3831 times)
Offline 003
« on: Fri, 25 July 2008, 22:27:34 »
Is there any place I can buy new blue cherry switches? Or maybe a cheap keyboard that has them?
Offline alpslover
« Reply #1 on: Fri, 25 July 2008, 22:38:45 »
Quote from: 003;6924
http://www.digikey.com
Offline 003
« Reply #2 on: Fri, 25 July 2008, 23:14:53 »
Thanks. Do you know the particular part number I am looking for? Digikey can be quite overwhelming.
Offline alpslover
« Reply #3 on: Fri, 25 July 2008, 23:47:49 »
either ch196-nd or ch197-nd depending on how the keyswitches will mount to the keyboard.  196 if the switches mount to a face plate above the circuit board, or 197 if there's no face plate.
