Author Topic: Noppoo Choc Mid 87 with Linux  (Read 1474 times)
Offline mattics
« on: Wed, 05 June 2013, 14:20:47 »
Hey guys,
Does anyone know if the Choc Mid works ok under Linux? I know the mini works (or at least a few posts here and there suggest it does) but I wasn't sure if they used the same/similar controller and I know that Macs aren't too happy with the mini.
Also the mid has a fully standard layout doesn't it? No quirky space bar or funny stem spacing?
Thanks in advance.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: Noppoo Choc Mid 87 with Linux
« Reply #1 on: Wed, 05 June 2013, 15:02:34 »
Linux is perfectly happy with the Choco MINI.
 - Ron | samwisekoi
Offline mattics
« Reply #2 on: Thu, 06 June 2013, 03:08:14 »
Thanks for confirming the Mini works, I would snap up a Mini but the limited replacement caps is a turn off.
I may just risk the Mid. I have a Leopold which I am pretty sure works with Linux, it just wasn't my plan to take it to work originally. Now to find a decent price in the UK...
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Thu, 06 June 2013, 04:57:23 »
You shouldn't run into any show-stopping issues.
The only thing that sometimes doesn't work are some extra macro/multimedia keys.
