Author Topic: TKL w/clears??  (Read 2645 times)
Offline lightsout714
TKL w/clears??
« on: Wed, 05 June 2013, 14:28:03 »
Why are TKL boards with clears so hard to find. I understand clears are rare. Supposedly qfr may be coming and wasd v2 one of these days.
Is my best bet just to get someone to customize a current board I have?
Offline missalaire
  • Great Finder of Great Finds
Re: TKL w/clears??
« Reply #1 on: Wed, 05 June 2013, 14:33:08 »
Yes, unless you can find someone selling a Leopold FC200R with clears.
Re: TKL w/clears??
« Reply #2 on: Wed, 05 June 2013, 14:40:12 »
Forgot about the Leo. Had one a while ago sold it to small fry. Thinking about just getting switches and have someone mod my qfr. But even switches are hard to come by/expensive.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: TKL w/clears??
« Reply #3 on: Wed, 05 June 2013, 15:01:14 »
I have a Leo with clears, nearly new, that I will be selling.
 - Ron | samwisekoi
Re: TKL w/clears??
« Reply #4 on: Wed, 05 June 2013, 15:27:53 »
PM'd
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: TKL w/clears??
« Reply #5 on: Wed, 05 June 2013, 15:35:08 »
be sure to mod the clears :D
-Enzo Ferrari
Re: TKL w/clears??
« Reply #6 on: Wed, 05 June 2013, 15:37:58 »
I am realizing I do not like the lighter switches. Its an error fest on browns now after using greens. And I wish the greens were a bit heavier.
Offline alaricljs
  • I be WOT'ing all day...
Re: TKL w/clears??
« Reply #7 on: Wed, 05 June 2013, 15:59:59 »
Depending on batch, clears can do with a bit of lube tho ;)
Filco w/ Imsto thick PBT
Offline DrinkTea
Re: TKL w/clears??
« Reply #8 on: Wed, 05 June 2013, 18:57:53 »
There's always the FC660M with clears. I just got that and it's very nice.
Re: TKL w/clears??
« Reply #9 on: Wed, 05 June 2013, 19:04:33 »
Thanks for pointing that out. Forgot about it. Kind of prefer TKL but the layout is pretty close.
Offline AJCarrington
Re: TKL w/clears??
« Reply #10 on: Thu, 06 June 2013, 08:55:00 »
Pretty sure the WASD V2 will have clears as an option.
Re: TKL w/clears??
« Reply #11 on: Thu, 06 June 2013, 10:12:37 »
Yah I think I mentioned that in op. I'll definitely take a look at them when they come out.
Offline phoenix1234
Re: TKL w/clears??
« Reply #12 on: Thu, 06 June 2013, 10:30:19 »
Actually, I think the default Cherry MX Clear's spring is very strong, for me it's even stronger than Cherry MX Green and  Black. I don't know why, perhaps it's just my feeling. So I suggest that if you go with Clear, you should change the spring with something lighter to create Ergo Clear.
I like linear switches
Re: TKL w/clears??
« Reply #13 on: Thu, 06 June 2013, 10:48:52 »
I like stiffer switches. I do remember that when I had clears they felt stiffer than the greens I have now. We'll see when ever I get some.
Offline DrinkTea
Re: TKL w/clears??
« Reply #14 on: Thu, 06 June 2013, 10:52:25 »
I think the overall force on clears might be less, but it feels like their actuation point is higher. I have a board with whites as well and I think those feel stiffer than clears. And if I'm not mistaken, white and green are very close.
Offline phoenix1234
Re: TKL w/clears??
« Reply #15 on: Thu, 06 June 2013, 11:41:15 »
Lightest to heaviest in actuation force: red/brown/blue, black, clear, white/green, lgrey/tgrey
Lightest to heaviest in bottom out force: red/brown/blue, black, white/green, clear, lgrey/tgrey
Here are figures from IvanIvanovich , I think it can explain why my fingers get tired quickly on the default Cherry MX Clear
Offline DrinkTea
Re: TKL w/clears??
« Reply #16 on: Thu, 06 June 2013, 11:44:31 »
Interesting that white/green and clear switch wrt activation and bottom out. Does that have to do with the stems? though I find my fingers get tired more quickly on the stock whites than clears. Although I still insist I need to toughen up my wuss pinkies.
Are there numbers for that or is it just an ordering. I'd like to see how much they actually differ.
Offline alaricljs
Re: TKL w/clears??
« Reply #17 on: Thu, 06 June 2013, 12:09:25 »
It's the force curve of the spring.  Clear's force curve is steeper, not sure if it starts higher tho...
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: TKL w/clears??
« Reply #18 on: Thu, 06 June 2013, 12:17:38 »
Keycool made one. Check their website and trace one through their taobao shop.
|||My other keyboards :
x
