Author Topic: Korean 80g springs = same spring in a MX Clear?  (Read 2243 times)
Offline lightsout714
« on: Wed, 05 June 2013, 14:46:34 »
Forgive the multiple threads.
Thread title says it all. Are these basically the same? If so can someone enlighten me why the korean ones would be better?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Korean 80g springs = same spring in a MX Clear?
« Reply #1 on: Wed, 05 June 2013, 15:46:39 »
As far as I have seen, they measure on the bottom out force, not the actuation force so I would guess that 80g is still lighter. Stock clear springs have a bottom out closer to 100g. I would guess these would be about the same as green/white.
Offline Dubsgalore
« Reply #2 on: Wed, 05 June 2013, 15:52:19 »
pretty sure green and white both have actuation forces of 80 cN, but bottom out forces are a bit higher. Clears have 55 cN actuation and 100g bottom out force
« Reply #3 on: Wed, 05 June 2013, 16:06:47 »
LOL. Yes you're right. though clears are 65 actuation not 55. I wish they would use the same ****ing measuring as Cherry. Damn confusing Koreans! So it would be like stock black springs then.
« Reply #4 on: Wed, 05 June 2013, 16:20:24 »
Ok thanks that clears it up. I'll be sticking to stock springs.
(bad pun not intended)
