Author Topic: how to make a homemade space key stabalizer?  (Read 3070 times)
Offline jer5010
« on: Fri, 07 June 2013, 22:38:34 »
My spacebar on my razer blackwidow keyboard got stuck so I took it off. Then the stabalizer bar broke. is there any way to make a homemade stabalizer for my spacebar?
Offline gnubag
Re: how to make a homemade space key stabalizer?
« Reply #1 on: Fri, 07 June 2013, 23:04:38 »
contact razer or buy some from wasdkeyboards.com
« Reply #2 on: Fri, 07 June 2013, 23:06:59 »
The razer uses a 7x spacebar. I don't think wasd stockers bars for this size.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #3 on: Fri, 07 June 2013, 23:08:45 »
Yeah the ones from WASD Keyboards are slightly different but it should still be compatible.  If not then you might have to buy mounting clips too.
Refer to this video:
Offline gnubag
« Reply #4 on: Sat, 08 June 2013, 00:41:26 »
it's a 6u spacebar.
and i assume that he broke one of the plastic parts and not the wire. so wasd should have what he needs.
