Author Topic: Can anyone ID this keyboard?  (Read 10706 times)
Offline 1391406
« on: Sat, 08 June 2013, 00:29:36 »
No brand on the front or back. Just a serial number. I like it. Anyone know what it is?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Can anyone ID this keyboard?
« Reply #1 on: Sat, 08 June 2013, 07:48:36 »
Terminal keyboard DEC LK201 alike. They were sold under several terminal equipment brands. It have MX black and SP doubleshot. I had similar Cherry G80-1306 version of that type of layout and there is earlier G80-0535 version too.
« Last Edit: Sat, 08 June 2013, 07:53:25 by IvanIvanovich »
« Reply #2 on: Sat, 08 June 2013, 08:27:55 »
I think this one is a "Falco".
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #3 on: Sun, 09 June 2013, 15:54:05 »
Most likely that's a rubber dome LK201-alike. Those are the most common by far, and the original genuine LK201 is a rubber dome. (You can trust me on this one. I have a genuine DEC VT220 in the house.)
The DIN5 is odd though. The genuine article is RJ11.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #4 on: Mon, 10 June 2013, 08:55:48 »
After a bit more googling, I am certain that it is the keyboard from a Falco terminal.
Offline ch_123
« Reply #5 on: Mon, 10 June 2013, 10:22:16 »
Not quite, the LK2** keyboards have a switch that is sort of like the Cherry MY (I think I used to have a picture of it here somewhere, but I have no idea if it lasted the move to the new forum software). The later LK4** keyboards use rubber domes made by Honeywell.
Offline rootwyrm
    • My Website!
« Reply #6 on: Mon, 10 June 2013, 13:19:40 »
Uh, no. The LK201 comes in rubber dome and foam over foil. This is an absolute fact. Are there some with mechanical or semi-mechanicals? Most likely. It's DEC.
But don't try and tell me they don't when I've got the genuine article right here. (Shush about the filth, it's a spare. :P)
« Reply #7 on: Mon, 10 June 2013, 14:54:18 »
As an additional aside, this layout exists in a lot of different keyboards. I've seen tektronix-branded ones with unknown switches as well as WYSE branded ones that may have cherry mx blacks in them.
Offline rootwyrm
    • My Website!
« Reply #8 on: Tue, 11 June 2013, 04:18:19 »
Yup, though none quite identical to the LK201. Trust me on this one. They all have differences.
For example, the LK201-compatible Tektronix 119-2468-03 which is one of my favorite "oddities" uses a joy-pad for the arrow keys. Even though the layout's otherwise identical. Wyse did some oddities with the F/PF key layout, though I can't recall what exactly. Nobody exactly copied the LK201 - probably for fear of getting sued. When the VT220 was popular (1983-1987) is when DEC was at its financial zenith. IBM was #1, and DEC was #2 with VAXen.
« Reply #9 on: Tue, 11 June 2013, 08:33:30 »
Really? Looks like Cherry 1306 is exact copy to me.
Offline rootwyrm
    • My Website!
« Reply #10 on: Tue, 11 June 2013, 15:39:47 »
Check again, sir. Layout's exactly the same, yes, except not. The F-keys on the Cherry 1306 are 1x1's - the LK201's are 1.1-1.2ish x 1. Same deal with Help/Do.
Offline ch_123
« Reply #11 on: Wed, 12 June 2013, 07:50:06 »
So do I, in fact, I've taken one apart before. If you open it up, you'll see that the white plastic part in your pictures is just a keycap mount. Underneath them, there's a row of metal hammers sitting over a membrane sitting over a backplate (the whole thing is secured together with plastic rivets just like a Model M). It's kinda hard to describe the mechanism properly (again, I used to have pictures and a diagram up here on the wiki about 3 years ago, but it seems to have been lost) but there's no rubber dome, no foam, no foil, and no capacitance plate. It's a switch that's a lot like the Cherry MY, except it's not self contained.
Of course, it's possible than they have made some different versions with different switches (are definitely some variations, for example, I've seen some with double shot keys, and some with dye sub), but your one there looks identical to the ones I've used and examined. Also, it's next to impossible to see the mechanism unless you open the case and look at the assembly inside, the pictures are inconclusive.
« Last Edit: Wed, 12 June 2013, 07:52:05 by ch_123 »
Offline rootwyrm
    • My Website!
« Reply #12 on: Wed, 12 June 2013, 13:20:36 »
Dude. I know what a rubber dome feels like as compared to a linear. This one looks like the linear but types like a rubber dome. It's a rubber dome. Pop-membrane similar to Unicomp where the keystem actuates. The linears don't have the bounce. I have a linear LK201-AA (which honestly, I hate too) hooked up to the white 220. It may be a post-marketing replacement part though - I don't have real solid provenance on the amber screen it came with.
As I said, it's DEC. Identical PN, different part is the norm with them. ;P
Offline tgujay
« Reply #13 on: Wed, 12 June 2013, 13:56:33 »
Pop a key off please?
Gotta collect them all
Offline 1391406
« Reply #14 on: Wed, 12 June 2013, 17:23:33 »
I don't have the keyboard. Just pics.
Offline tgujay
« Reply #15 on: Thu, 13 June 2013, 07:25:29 »
You have failed me.  I will spend the rest of my life never knowing what was under there.
Offline Aerendraca
« Reply #16 on: Fri, 28 March 2014, 11:28:39 »
I couldn't let this go unresolved so I thought it was time to register with geekhack and provide my first bit of knowledge.
This keyboard is a Falco 5220 taken from a Falco High-Speed Infinity (LOL) Terminal. I can alos tell you that under the hood are 109x (if I remember correctly) Cherry MX Black switches.
Here's some pics (sorry about the orientations, was in a hurry):
« Last Edit: Fri, 28 March 2014, 12:06:58 by Aerendraca »
Offline Red October
« Reply #17 on: Fri, 04 January 2019, 16:01:46 »
Sorry for the Ultra Gravedig, but I just pulled apart a junk one of these keyboards and I can confirm 100% it is for a Falco 5220 Terminal as it says "Falco 5220" on the bottom of the circuit board.  Thought I'd add information to the thread for the enlightenment of future searchers.
