Author Topic: Trackball - PS2 pin-out?  (Read 17532 times)
Offline Tarzan
  • formerly known as Greystoke
« on: Mon, 10 June 2013, 18:24:26 »
So I'm trying to follow a pretty old thread about modding the Marquardt HEROS military keyboard from DIN connector to PS2 (or maybe two PS2...) connectors.  I can follow the pin-out chart okay, but it just seems to map the connections between the DIN connector and the PCB connector.
http://geekhack.org/index.php?topic=8016.0
So how do I tell which wires to solder to a PS2 connector?  Probably some information was included in the pictures, which are completely missing.
I also can't tell from the text if the OP used a single PS2 connector, or two; one PS2 connector for the keyboard port and the trackball signal on a different PS2 for the mouse port.
The DT Wiki has a lot of images, not sure if these came from the GH thread or not.
http://deskthority.net/wiki/Marquardt_Military_Keyboard_7069.3111
Any pointers or ideas?
Offline Tarzan
Re: Trackball - PS2 pin-out?
« Reply #1 on: Mon, 10 June 2013, 18:56:18 »
Found this pin mapping diagram:
It appears that I can use two PS2 connectors for the mouse and keyboard.  Time to find some spare PS2 connectors and test it out...   ;D
Offline codyeatworld
« Reply #2 on: Mon, 10 June 2013, 19:09:24 »
Let me know if the ps/2 cables work :)
My trackball has broken plastic part inside that I'm gonna see if crazy glue can fix.
Offline Tarzan
« Reply #3 on: Mon, 10 June 2013, 19:14:58 »
The original thread I linked above mentioned a broken bit in the trackball housing, too.  I suspect it's an easy area to damage, as the trackball protrudes above the case and the keys.  I'd bet someone stacked two or three of these 8-pound boards on top of each other at some point in the selling/shipping process.
Btw; I couldn't figure out what the black ball icons were on the top number pad keys.  Then I was re-reading the old Marquardt thread, and a light dawned; these are the trackball buttons.  Yep, I'm kind of slow sometimes...   :p
