Author Topic: WASDkeyboards and czech letters  (Read 2598 times)
Offline SOROBORU88
« on: Tue, 11 June 2013, 11:22:28 »
Greetings,
I!ve already posted this question, but maybe the situation has changed :) Are WASD able to print keycaps with czech letters? Czech letters are those: ěščřžýáíé and they are situated on the number row. ě is on 2 and é is on 0 keycap.
Thank you for your answers.
Offline RabRhee
Re: WASDkeyboards and czech letters
« Reply #1 on: Tue, 11 June 2013, 18:40:41 »
Their custom keyboard designer does let you enter extended characters from the fonts they allow, like Arial, Wingdings, etc. That does allow you to enter Arial vowels like alt-0234 ê, and áéí, . Also the š and ý are in the Arial second half. no clue if the c, r and z versions exist in any of their standard fonts though. Whether they actually print them is another matter only they can answer, but I got a wingdings extended character printed by them without any stress.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #2 on: Tue, 11 June 2013, 22:05:22 »
You can use their PDF design templates and supply a font that will work.
Send them an e-mail for fastest reply.
 - Ron I samwisekoi
