Author Topic: Buying new keyboard  (Read 1399 times)
Offline smoke070
Buying new keyboard
« on: Thu, 13 June 2013, 01:29:48 »
Hello :) looking to buy a new keyboard. Currently have a Das Professional Quiet (brown switches). Bought in late 2010.
What I want:
-Blue switches (or whatever is clicky as possible)
-Number pad
-Backlit
-QWERTY
-NKRO
Hmm.. think that's it. I'm not sure if such a keyboard exists but hey.. figured i'd see what's out there. :D Thanks in advance!
« Last Edit: Thu, 13 June 2013, 01:31:27 by smoke070 »
Offline smoke070
Re: Buying new keyboard
« Reply #2 on: Thu, 13 June 2013, 12:33:21 »
Thanks for the help. I'm deciding between these now..
Black keys - chinese w/ white LED
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=347
The only thing with this one is i'm wondering if the chinese characters will make everything seem too busy looking? I assume they light up.
White keys - blue LED
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=325
Not sure if i'm digging the white keys, and I can't find any youtube videos of this particular one to look at the backlight. But I would prefer a blue backlight.
Offline shifted
« Reply #3 on: Thu, 13 June 2013, 13:10:19 »
Wait a couple weeks for the shine III or the zero shine to be released if you want a ducky in my opinion.  They will probably be cheaper than the current stock.
I have this keyboard and love it.  I have it in red switches but they make it in blue as well.  They are out of stock on Max keyboard's website currently though for the blue switches.  I chose it over the Ducky because I like the costar stabilizers better.  It has full n key roll over over usb as well.  No need to mess with PS/2
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=313
« Last Edit: Thu, 13 June 2013, 13:34:46 by shifted »
