Author Topic: Noppoo Choc Mini odd LED placement and labels.  (Read 2210 times)
Offline Floor
« on: Thu, 13 June 2013, 16:17:07 »
I have a Noppoo Choc Mini that I ordered through Qtan, and I've recently noticed that the lock LED's are placed adjacent to the keycaps, and not directly underneath with a window in the keycap like all of the other Choc Mini's I have seen. It also lacks an LED for Insert.
My board:
http://i.imgur.com/rKC5Efr.png
http://i.imgur.com/hflrxAn.png
http://i.imgur.com/xRBtuyk.png
http://i.imgur.com/zzBuYfM.png
http://i.imgur.com/QoiE9mx.png
http://i.imgur.com/p83KpOE.png
Board LED's I commonly see:
http://i.imgur.com/90E4hov.jpg
It also had Fn labels on the R and F keys for stopping media and disabling the windows key, but I've since removed the Fn labels so I don't have a picture. I also don't see this on other of the same boards.
Other than this the board feels fine, I'm wondering if it's an old model or why I've never seen one like it.
Edit: Added more pictures. Again, there were labels on the front face of the keys for alternate functions, but I removed them.
« Last Edit: Thu, 13 June 2013, 19:07:59 by Floor »
Offline dadgh
Re: Noppoo Choc Mini odd LED placement and labels.
« Reply #1 on: Thu, 13 June 2013, 17:29:10 »
take a full picture of the board
Offline jabar
« Reply #2 on: Thu, 13 June 2013, 18:07:39 »
remove the keycaps, see if the LEDs are mounted in the switches as they should be.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline alrgeez
« Reply #3 on: Thu, 13 June 2013, 22:20:01 »
mine definitely doesn't look like that. looks like the retail picture you posted up.
i<3myKB
Offline Surnia
« Reply #4 on: Thu, 13 June 2013, 22:24:26 »
Interesting, the Noppoos seem to change design/OEMs so quickly its hard to track... odd however, that its a POM version with a non-detachable cable.
Noppoo Choc Mini with MX Black | Filco 104 MJ2 Ninja with MX Black
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 14 June 2013, 08:58:23 »
Your 2013 version is different from the older ones. Seems quite odd they decided to place the led between the rows though.
