Author Topic: O-rings for Spherical Keycaps?  (Read 3535 times)
Offline tricheboars
  • Keyboards are Important!
« on: Thu, 13 June 2013, 23:40:43 »
Sup,
   So i got a set of the round 4 spherical keycaps today and i wanted to install o-rings on them.  The problem is that the stems are so deep inside the keys that they never actually hit the o-rings that i installed. Does anyone know of any really thick soft o-rings. i usually use 50a.
the caps are dope as **** though. they arent that loud either. probably because the caps are so thick.
first world problems...
Offline Hak Foo
  • Make America Clicky Again!
Re: O-rings for Spherical Keycaps?
« Reply #1 on: Fri, 14 June 2013, 00:17:54 »
What happens if you stack two?
Overton130, Box Pale Blues.
Offline tricheboars
« Reply #2 on: Fri, 14 June 2013, 00:32:47 »
i....dont know. i hadnt thought of that.  to the test chamber!!
update edit: they dont stack well. what are soft landing pads?
« Last Edit: Fri, 14 June 2013, 09:08:21 by tricheboars »
Offline nsrexler
« Reply #3 on: Fri, 14 June 2013, 09:47:06 »
I've heard this is a problem with SP caps in general, since they don't have the cross bracers. I don't remember if a good solution was ever found.
« Reply #4 on: Fri, 14 June 2013, 09:50:14 »
Tricheboards, check my signature. I have a review on o-rings and soft landing pads. Maybe if you stack a soft landing pad and an o-ring?
Offline CommunistWitchDr
  • >implying keyboards
« Reply #5 on: Fri, 14 June 2013, 10:01:14 »
For anyone else on tapatalk-
http://wiki.geekhack.org/index.php?title=User_talk:CPTBadAss
Offline tricheboars
« Reply #6 on: Fri, 14 June 2013, 13:15:24 »
thanks i use tapatalk
« Reply #7 on: Fri, 14 June 2013, 13:17:44 »
Oops, I'll try to be less lazy in the future ^__^
Offline tricheboars
« Reply #8 on: Sun, 16 June 2013, 23:59:13 »
what about some kind of dampener that lies on the plate? that is the only way i can think these SPH caps are going to not bottom out.  they are quieter than most caps bottoming out since they are so thick i just want to use them at work...
