Author Topic: sensei did not work,perhaps mlg?  (Read 3312 times)
Offline typo
« on: Sat, 15 June 2013, 03:34:02 »
the sensei would not work on my mouse pad. I am not getting rid of this pad. I was wondering what is the likelihood the mlg would work? the store is 90 miles away so if I have to bring it back I will not be happy. is it worth the risk to find out or it is probably the same? oh, the xai did not work either. I tried every lift setting on both too.
Offline Reomero
  • Manual breather
Re: sensei did not work,perhaps mlg?
« Reply #1 on: Sat, 15 June 2013, 03:52:11 »
What mousepad are you using?
If I were you, I'd get a cheap QcK or Goliathus via Amazon or something.
Offline typo
« Reply #2 on: Sat, 15 June 2013, 04:07:18 »
the thing is I have a discontinued mouserug.com that I do not wish to part with. it was not about money or something.  I am not gaming. I just need the mouse to not skip all over. other mice work fine but the sensei and xai did not. I don't know is something is the same on the mlg as well or different.
Offline vun
  • Just one more thing
« Reply #3 on: Sat, 15 June 2013, 05:05:48 »
Well, the MLG does have a different sensor, but honestly I'd say it's not worth the risk.
