Author Topic: G80-3000  (Read 3189 times)
Offline Meatcleaver
G80-3000
« on: Sun, 16 June 2013, 08:55:43 »
Hi, wanted to ask if any of you knows what KRO the following G80 could have:
Article No.: G80-3000 HED/09
Serial No.: 000911   C28 V
FCCID: GDD5YOG80-3000
Hope thats enough Info
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: G80-3000
« Reply #1 on: Sun, 16 June 2013, 09:13:31 »
Doubleshot keycaps, should have clear switch, German layout. Probably 2KRO.
Offline Meatcleaver
Re: G80-3000
« Reply #2 on: Sun, 16 June 2013, 09:43:20 »
Darn it, was hoping that it might be old enough to be nkro.
Well, gonna follow it anyways. MAybe I can get a cheap ride into the mechanical world with it.
Re: G80-3000
« Reply #3 on: Sun, 16 June 2013, 10:44:37 »
Most 3000 models are only 2KRO, though there are some with NKRO. Unless you can see diode under the stem, and not just a jumper wire is only way to tell for sure. Model number is usually not enough, though the /09 says it's a later revision so it is not as likely. Even still, if it is a good price you get some clear switch and doubleshot keycaps so it can still be worth buying. Even 2KRO is fine for any non-gaming for most people. Even then it depends a lot on what games you play, some the 2KRO is not a problem like most RPG for example.
Offline Halvar
Re: G80-3000
« Reply #4 on: Sun, 16 June 2013, 10:55:59 »
I tried the classic quick-brown-fox test with an old winkeyless G80-3000 HFD from 1994 and it went perfect:
THE QUICK BROWN FOX JUMPS OVER THE LAZY DOG
There are no diodes visible in the switches under the stems (like on a G80-1000), just 5 diodes visible on the whole PCB
Meanwhile on a modern G80-3000 with USB I get this:
HE QUIK BROWN FO JUPS OER HE LA DOG
So I think there's a good chance that you are lucky.
Offline Meatcleaver
Re: G80-3000
« Reply #5 on: Sun, 16 June 2013, 11:18:09 »
The one I mentioned is supposed to be using a 5 pin Din connector.
Could be an old one then. Im not sure...maybe I should try it :)
Offline Meatcleaver
Re: G80-3000
« Reply #6 on: Sun, 16 June 2013, 13:30:44 »
Btw: Has anyone heard of AT A-2 KB 2101/2? Supposed to be made by a company named A-2 Technology in Taiwan
Looks pretty good, MX Blue, double shots.
Offline Halvar
Re: G80-3000
« Reply #7 on: Sun, 16 June 2013, 14:22:35 »
Yeah, you should have got the Cherry IMO, the price it ended at was quite ok for a G80-3000 with 2Shots and MX clears.
I haven't heard of the A-2 before, but from the auction and video it seems descent, and Cherry MX blues are very nice switches (if you are OK with the loud click). The keyboard doesn't seem quite as good as an old Cherry though. Look at the thin keycaps.  I could be wrong here. If it stay under 20€ it's worth buying imo.
The problem with discussing running auctions on GH is always that a swarm of lurkers might read this and become interested ...
Offline Meatcleaver
Re: G80-3000
« Reply #8 on: Sun, 16 June 2013, 14:35:10 »
The Cherry stayed at 12 € until 5 secs where it went up to 25 € on the last second. Wasn't able to snipe it that fast tbh :)
