Author Topic: Can anybody identify this keyswitch?  (Read 4674 times)
Offline Dimswitch
« on: Mon, 17 June 2013, 13:30:39 »
25673-0
Close up:
25693-1
« Last Edit: Tue, 18 June 2013, 04:08:47 by Dimswitch »
Offline tgujay
Re: Can anybody identify this keyswitch?
« Reply #1 on: Mon, 17 June 2013, 14:06:14 »
Not sure, looks similar to Space Invaders but definitely isn't.
Gotta collect them all
Offline Dimswitch
« Reply #2 on: Mon, 17 June 2013, 14:08:41 »
Yeah, it almost looks like a captive buckling spring in there to me... But like no IBM Ive ever seen
Offline Dimswitch
« Reply #3 on: Mon, 17 June 2013, 16:24:49 »
Nobody knows anything about it?
« Reply #4 on: Mon, 17 June 2013, 16:28:35 »
Omg, no one responded in an hour....have a little patience
Offline CommunistWitchDr
  • >implying keyboards
« Reply #5 on: Mon, 17 June 2013, 16:34:48 »
No it doesn't. It looks like a spring over membrane to me, but I could be wrong.
Offline Dimswitch
« Reply #6 on: Mon, 17 June 2013, 16:50:40 »
Alright. I'm sorry if my posting bothered you, but considering the mountains of collective keyboard knowledge which browse this board, a single bump after an hour of no response in prime time (for a topic like this) isn't really what I would call terribly impatient...
And to be honest, it seems like something people might be interested in.
But I've been wrong [many times] before...
Offline Dimswitch
« Reply #7 on: Mon, 17 June 2013, 16:52:48 »
Interesting. And I'm sure you're right, at the very least about it not being a buckling spring - it just wouldn't be long enough.
Offline Jack Karneval
  • I'm gunna pop some keys, only got $20 in my pocket
« Reply #8 on: Mon, 17 June 2013, 16:59:16 »
Nothin for nothin, but it looks awfully similar to a hall effect switch, which I happened to look up today...
example...
: CM Storm Trigger (MX Green) : KBT Pure Pro (MX Blue) :
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #9 on: Mon, 17 June 2013, 17:05:59 »
Definitely not hall effect, not with the exposed portion like that..
Not 100% sure myself, but that actually looks like it could be a previously unknown SMK. Could be that SMK built on contract specific to those keycaps for the ODM?
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline Dimswitch
« Reply #10 on: Tue, 18 June 2013, 02:29:47 »
I've been trying to find an SMK switch mechanism that matches up but I've been unsuccessful so far... However, this ALPS plate spring switch looks similar... (http://deskthority.net/wiki/Alps_plate_spring)
Offline Dimswitch
« Reply #11 on: Tue, 18 June 2013, 09:36:33 »
Well somebody sniped the auction out from under me, lol. Hope it was someone here-I want to know what that switch is.
link: http://www.ebay.com/itm/140995393986?redirect=mobile
« Last Edit: Tue, 18 June 2013, 09:40:34 by Dimswitch »
« Reply #12 on: Tue, 18 June 2013, 12:31:21 »
example...
I'm sure it's different than the IMSAI hall effect switches (shown) and it's definitely not microswitch hall effect.
My guess would be an alps plate spring knockoff, but I really have no idea.
Offline rootwyrm
    • My Website!
« Reply #13 on: Tue, 18 June 2013, 12:42:25 »
I don't think the Alps looks similar. Not compared to the SMK Cherry MX Mount - note the exposed centered spring. The actual switch looks like the entire upper frame was removed and they bastardized an inverse cross mount to make a full-sliding frame half. One of SMK's hallmarks was the exposed spring, it seems, which is why I immediately thought SMK. But that's some serious frame changes for a contract run.
Offline hjalfi
« Reply #14 on: Sun, 05 May 2019, 14:33:22 »
I know this is a bit of a necropost, but the image here is really prominent when searching for this particular kind of keyswitch, and I managed to identify it: it's a SMK discrete dome-with-slider job commonly found on Canon typewriters. Here's a teardown:
https://deskthority.net/viewtopic.php?f=62&t=19859&start=
I really like mine; it's a very light, almost floaty thing, mostly linear but with a subtle but pleasing tactile event at the bottom. Very quiet. I've been thinking about converting my typewriter keyboard to USB, but it doesn't really have enough keys, so I'm interested to see that they made PC keyboards with them. Assuming the OP is still around after six years, what keyboard is that?
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #15 on: Sun, 05 May 2019, 14:43:22 »
OP was last active 2 weeks after creating the profile so you will most likely never know.
Offline frydaja
  • "It's my last keyboard, I swear"
« Reply #16 on: Sun, 05 May 2019, 15:22:37 »
The keycaps look too similar to Cherry's keycaps. Maybe a switch somewhere between their foam&foil and MX?
Or was there a keyboard manufacturer who used this exact Helvetica font?
Anne Pro 2 w/ Kailh Box Browns | CM Storm Quickfire TK Stealth w/ MX Browns | Unknown Chinese keyboard w/ Outemu Reds | Compaq-branded NMB RT101 | Gigabyte Force K81 w/Kailh Reds
« Reply #17 on: Sun, 05 May 2019, 17:09:58 »
Cool find of this old thread!
The Datadesk keyboard does not have the same keycap profile as the Canon typewriters. But several Canon's typewriters tend to have similar keycaps between themselves: with this SMK switch (this mount and SMK inverse cross-mount), Alps switches or a type of spring-over-membrane switch. They share the same font and colour scheme but some are cylindrical and some are spherical.
