Author Topic: Pure Replacement Keycaps  (Read 2166 times)
Offline therecorder
« on: Mon, 17 June 2013, 22:51:21 »
Has anyone used these for a backlit Pure?  Do they permit the light to get through so that you can read the legends?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=288
Offline kelske
  • The North Borders
Re: Pure Replacement Keycaps
« Reply #1 on: Tue, 18 June 2013, 04:47:56 »
I highly doubt that they will. PBT doesn't let light through very well.
Generally the backlight compatible keycaps are ABS and have a specific printing method to be used successfully with backlighting. e.g. the keycap plastic is actually white/clear and it has a special black layer on the top of the keycap - minus the legends.
Offline laffindude
« Reply #2 on: Thu, 20 June 2013, 07:54:22 »
Yes.
No.
