Author Topic: Swapping keycaps on a Qpad?  (Read 1797 times)
Offline Masterchief79
« on: Tue, 18 June 2013, 10:46:46 »
Hey you guys,
wanna buy the Toxic keyset. It won't fit on my Qpad MK50 because of the right Modifiers, am I right? Because Enter, Backspace and stuff are not like x2.0 but like x1.95 or something?^^
If I am correct, does someone want to buy a Qpad MK50 with German ISO? :P
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Swapping keycaps on a Qpad?
« Reply #1 on: Tue, 18 June 2013, 12:16:28 »
You could put Toxic set on qpad if you really wanted. You would need base, winkeyless mods, ISO kit, numpad. Only thing that you can't get from toxic set is a matching spacebar that will fit. Same thing applies with pretty much anything else that is made from iOne regarding compatible with any keycaps that are not from iOne.
« Reply #2 on: Tue, 18 June 2013, 13:18:12 »
Really? I always thought, QPad was using a non-standard layout on those right modifiers because my cherry keys didn't seem to fit. Well, thanks^^
« Reply #3 on: Tue, 18 June 2013, 13:22:23 »
Bottom row is 1.5, 1, 1.5, 6, 1.5, 1, 1, 1.5. Everything else is as usual.
