Author Topic: Is this Buckling sping or RD?  (Read 1955 times)
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« on: Wed, 19 June 2013, 03:48:00 »
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Re: Is this Buckling sping or RD?
« Reply #1 on: Wed, 19 June 2013, 03:54:08 »
Dirty as hell, but looks like a BS M to me.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Wed, 19 June 2013, 04:13:15 »
That's a buckling spring M absolutely, yes. Rubber domes didn't get the two-piece keycaps.
Mechanical is usable as spare, but they're POS keyboards - not AT. No idea if you could do a controller swap without knowing the models, but usually yes.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #3 on: Wed, 19 June 2013, 06:57:36 »
You're not looking for spare left alt caps, right? Because the board pictured does not have a left alt cap, and as such would be an unreliable source of some.
I guess you could use the right alt as a left alt, but that's kinda sketchy.
« Reply #4 on: Wed, 19 June 2013, 08:14:31 »
Controls and Alts are the same and will interchange.
At that price, it is less than the $30 most places charge for a set of key caps alone, even if they are missing a few.
- Oliver Willis 2026-08-01
« Reply #5 on: Wed, 19 June 2013, 08:20:24 »
My post was mostly a joke, figured the last part about not using the right alt would give it away. Probably good to clarify for people new to model m caps though.
But yeah, the price look fair for spare springs, caps, and case even if you can't get it working.
« Reply #6 on: Wed, 19 June 2013, 09:29:13 »
Oops, didn't notice it without the sarcasm switch.
A Model M delivered in the low-$20 range is a good price for anybody who needs a pile of parts. I would not bother trying to convert a terminal to a daily driver unless there was some other compelling reason, such as putting a Model F into regular service.
However, with all the projects going on such as chopping and bolt-modding, I can see things like cases, plates, and springs having value for experimentation and replacement.
Also, a nearly-complete set of keys might come in handy for RIT dyeing projects and interesting color enhancements.
Offline rootwyrm
    • My Website!
« Reply #7 on: Wed, 19 June 2013, 17:55:22 »
Oh gods no. Totally disagreed, especially on the POS boards. When they're the POS controller with the M matrix it literally is trivial to use them on a PC. You disconnect the matrixes, swap in a PC controller board, reconnect the matrixes and that's it. (Okay, and use the SDL to PS2 cable instead.) Also, some later POS boards actually speak AT over RJ45 - so it's just an RJ45->DIN6 connector adapt - but I can't even identify them by PN. :(
