Author Topic: 38GT - Resistors - One final question  (Read 2080 times)
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« on: Wed, 19 June 2013, 13:41:48 »
Hello,
I am building a 38GT (not mine) - will 1N4148 diodes be alright?
Thanks
« Last Edit: Thu, 20 June 2013, 08:14:38 by margo baggins »
I got boards.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: 38GT - Diodes?
« Reply #1 on: Wed, 19 June 2013, 15:45:38 »
Hello,
Thanks
Those are the diodes GON told me he uses on his 38GTs so I think those will be fine.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: 38GT - Diodes?
« Reply #2 on: Wed, 19 June 2013, 15:53:59 »
Those didoes will work fine.
-Enzo Ferrari
  • Dungeon Dweller
  • Get back to work!
Re: 38GT - Diodes?
« Reply #3 on: Wed, 19 June 2013, 15:56:16 »
awesome thanks for your responses  :)
I got boards.
  • Dungeon Dweller
  • Get back to work!
Re: 38GT - Resistors
« Reply #4 on: Wed, 19 June 2013, 19:31:15 »
Excuse the double post - do you know which resistor I will need for the LEDs? They are SMD's but which are most suited?
I got boards.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Wed, 19 June 2013, 20:04:40 »
http://ledcalc.com
It's LED specific in regard to how much resistance you need.
Filco w/ Imsto thick PBT
Offline WhiteFireDragon
    • youtube
« Reply #6 on: Thu, 20 June 2013, 01:39:35 »
The size you want is 0805. Resistors for LEDs don't need very high tolerance values, so just pick the cheapest one. You can get thick film SMD resistors for less than a penny each if you buy 100.
The resistor value to choose will depend on voltage of the LED, like alaricljs said.
  • Dungeon Dweller
  • Get back to work!
« Reply #7 on: Thu, 20 June 2013, 04:06:25 »
hello, thanks for the replies - I know I need different resistance for different colours, 0805 was what I was after - thanks dudes! :)
I got boards.
  • Dungeon Dweller
  • Get back to work!
« Reply #8 on: Thu, 20 June 2013, 06:53:08 »
I'm getting really confused trying to work out these resistances.
The LEDs are wired in parallel on the board? I want to use white and red LED's that 3.3v and 2.4v respectively, 25mA would be fine. Can you offer any assistance?
« Last Edit: Thu, 20 June 2013, 12:57:56 by margo baggins »
I got boards.
Re: 38GT - Resistors - One final question
« Reply #9 on: Thu, 20 June 2013, 11:34:37 »
i'm not familiar with the board in question, but often, the LED's are wired between a 5V power "rail" and ground, each with a resistor in series with the LED for the purpose of current limiting.
If this is the case with your board, you should be able to use the calculator for a 5V source, and use that value resistor for them all.
Of course, I'd wait for another person with 38GT experience to chime in before committing to a value, but at least now they can quote this post and agree or disagree.
I could tell you for sure if I had a layout diagram, or even good pictures of both sides.
