Author Topic: Keycool84 slow numpad.  (Read 1309 times)
Offline ImperfectLink
« on: Wed, 19 June 2013, 15:43:37 »
Hi there everyone. I just purchased a Keycool84 from mechanicalkeyboards.com and while the quality seems to be pretty good, the only way to get the numpad working is FN+numlock. Fr some reason I was under the impression that FN+numkeys would do it sort of like holding shift for caps.
Usually when I use numkeys, it's just a zero or a period here and there so stretching my hand to turn on numlock, pressing zero, then turning it off is not an ideal process. Does anyone know a better way or a way to hack the firmware? Should I just send the board back?
Offline jabar
Re: Keycool84 slow numpad.
« Reply #1 on: Wed, 19 June 2013, 17:34:50 »
As far as I've ever known, the internal numpad on all TKL boards is a full toggle, not internal Fn+n keypresses. The Fn key is only recognized within the keyboard as it itself sends no scan code.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline ViewMaster
« Reply #2 on: Wed, 19 June 2013, 18:25:42 »
I just bought one of these. I was under the impression that FN was toggle.
« Reply #3 on: Wed, 19 June 2013, 18:41:37 »
I wouldn't mind if the toggle wasn't such a stretch to get to. I guess I'm still looking for a keyboard then. I appreciate the replies.
« Reply #4 on: Thu, 20 June 2013, 08:55:13 »
I did a reg hack that makes the CapsLock into a NumLock. Problem solved!
« Reply #5 on: Thu, 20 June 2013, 09:13:49 »
Oops, the top row 3 key sticks and it's the switch. I may have to write a review about my experience. It's too bad cause I'm really enjoying the layout.
