Author Topic: Buy keyborad keycaps in France ?  (Read 2799 times)
Offline GlowingStar
« on: Thu, 20 June 2013, 06:53:56 »
Hi,
Just a "simple" question : Do you know if/where I can buy key caps in France, or at least ship it there for a reasonnable price ?
Thanks.
Re: Buy keyborad keycaps in France ?
« Reply #1 on: Thu, 20 June 2013, 16:59:09 »
Most keycap manufacturers are in the US, or China, with a couple in the UK.  UK might be your best bet as it is closest.
Try QWERkeys for a start: http://www.qwerkeys.co.uk/
And depending on what you want, these guys have a few too: http://www.keyboardco.com/
Offline GlowingStar
« Reply #2 on: Fri, 21 June 2013, 01:11:12 »
Thank you very much for your answer, I will try these ones.
