Author Topic: Things you did not want to learn...  (Read 5036 times)
Offline lowpoly
« on: Fri, 22 August 2008, 14:44:17 »
I had just prepared two keyboards for the dish washer, keycaps in the cutlery basket and all when I realized there were no more dishwasher tabs. And shops were closed.
Well, a quick search on Google showed that it seems to be common knowledge, but I did not know that you must not use dishwashing liquid instead.
After a while the dishwasher didn't make its usual washing noise. I opened the door and found tons of foam :eek:. I had to take it out all by hand. Several times.
Now it seems to do its job again. I hope. I should just check it once more.
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #1 on: Fri, 22 August 2008, 20:52:24 »
Hey...I did that once.  ONCE.  Took the dishwasher out of commission for about a week.  =-D
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline iMav
  • geekhack creator/founder
« Reply #2 on: Fri, 22 August 2008, 21:44:19 »
I had that happen once to me as well.  Suds were coming out of the dishwasher (forced past the seal).  I used them to wash down the counter and mop the floor.
Actually worked out pretty well.  :)
Offline D-EJ915
« Reply #3 on: Fri, 22 August 2008, 23:18:45 »
Quote from: iMav;7750
nice job making it work out, lol
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Sat, 23 August 2008, 13:05:10 »
This is the offtopic forum, so...
I didn't want to learn that, even if you have no plans of engaging the clutch, selecting 1st gear at 40 MPH makes the clutch spin much, much faster than it's designed to spin. 8000 RPM makes a VW diesel clutch go *boom*.
Like this:
:eek:
(The engine was in no danger at any point in this, but still...)
