Author Topic: Abyssus broken microswitch  (Read 6566 times)
Offline FuelxD
« on: Fri, 21 June 2013, 20:31:56 »
hello! here is my problem and my question:
the right click of my abyssus mirror is broken (the microswitch dont work)
can i change it for other microswitch from other mouse?(mouse genius xscroll)
are all the microswitch compatible?
or maybe change for the wheel s microswitch?
thanks!
Offline damorgue
    • Personal portfolio
Re: Abyssus broken microswitch
« Reply #1 on: Fri, 21 June 2013, 20:40:11 »
Offline FuelxD
« Reply #2 on: Fri, 21 June 2013, 20:52:56 »
http://dx.com/p/diy-mouse-micro-switch-20-piece-pack-122495
Now you are set for a lifetime.
please answer me .....  all microswitch works in all mouses?
thanks!
« Last Edit: Fri, 21 June 2013, 20:54:39 by FuelxD »
Offline damorgue
« Reply #3 on: Fri, 21 June 2013, 20:55:54 »
I think so. They basically just close the connection between the pins. Some have a lever and or roller on top which aren't needed for any mice I have seen. I have used the linked ones in my MX500. Before that, I ripped one from another mouse and my MX500 is still alive and well.
Edit: I was in no hurry when I got the ones linked above. They have free shipping and the switches themselves are dirt cheap, but the delivery time is kind of long. You may be able to get them faster locally.
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #4 on: Fri, 21 June 2013, 21:00:34 »
Most of them use Omron switches (chinese and  japonese) on left/right buttons and TTC on side buttons. I saw other brand in my Taipan (dpi buttons) but I don't remember the name.
The wheel's switch can be different. You need to open and check it.
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline FuelxD
« Reply #5 on: Fri, 21 June 2013, 21:13:46 »
ok
in my mouse the right and left are Omron and the wheel's switch is TTC
but the other switch that i have (from the other mouse) isn't ttc or omrom
will it work? are all the same and only are differents brands? or they works different?
thanks.
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #6 on: Fri, 21 June 2013, 21:18:05 »
I think so. If they also have those 3 pins to solder.
Offline damorgue
« Reply #7 on: Fri, 21 June 2013, 21:19:54 »
If you read on the side, what letters does it say for the pins? Something like C, NO and NC?
Offline FuelxD
« Reply #8 on: Fri, 21 June 2013, 21:31:23 »
all the 3 switch from genius mouse say C NO NC
the right switch from razer mouser say 1252c41 china d2fc f 7n
and the left 0662c41 china d2fc f 7n
i cant see what say wheel switch
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Sat, 22 June 2013, 22:40:47 »
Use some good ones if you don't want it to break again. Cherry DG2 or Omron D2F-01F if you like something lighter to press.
If you don't really care all that much I have some Omron something or rather that I pulled out of a logitech when I put in some D2F-01F you can have if you need.
« Last Edit: Sat, 22 June 2013, 22:42:32 by IvanIvanovich »
Offline FuelxD
« Reply #10 on: Sun, 23 June 2013, 00:09:41 »
ok that is nice thanks!
