Author Topic: Yellow pbt keycpas?  (Read 3614 times)
Offline jonathanyu
Yellow pbt keycpas?
« on: Fri, 21 June 2013, 20:59:47 »
I want to find a set of 87keys side printed yellow pbt keycaps ,but I can't find it anywhere. :(
Does anyone know where can I find it?
Either thick pbt or regular pbt is okay for me. :)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Yellow pbt keycpas?
« Reply #1 on: Sat, 22 June 2013, 06:25:31 »
Found some on taobao, only lasering though.
Offline jonathanyu
« Reply #2 on: Sat, 22 June 2013, 08:55:55 »
:)I also find some on taboo, but I really don't know how to buy from taboo :(
« Reply #3 on: Sat, 22 June 2013, 11:34:11 »
You need to see if Chinese forum member may help you, or not you need a taobao agent like bhiner, mistertao or something.
Offline jonathanyu
« Reply #4 on: Sat, 22 June 2013, 14:15:23 »
 ;)Thank you for telling me how to buy for taobao
Unfortunately, I can't find any yellow pbt keycaps that look good :(
So I am thinking of double shot keycaps in red and white
http://item.taobao.com/item.htm?spm=a230r.1.14.24.MtDid7&id=15735905905
The keycap in this website look awesome.
But it's still booking only...so can I still buy it through bhiner?
« Last Edit: Sat, 22 June 2013, 18:55:12 by jonathanyu »
« Reply #5 on: Sat, 22 June 2013, 22:21:45 »
If you decide for doubleshots, those on the page you linked were from a groupbuy here, red alert or klaxon? Both are ended for ordering, but you might be able to take over an order or get set later in the classified. For a cheap entry something kind of similar, you could get in on the Tai Hao buy if you don't mind wait a little bit. Otherwise take a look around the groupbuys section for things that are not ended for ordering.
Offline jonathanyu
« Reply #6 on: Sun, 23 June 2013, 01:04:55 »
 :)That sounds good
