Author Topic: O-rings of unusual size  (Read 5717 times)
Offline Cataphract
« on: Sat, 22 June 2013, 16:43:19 »
I have been using 3mm thick, 5mm ID 70A o-rings for quite some time now. I have been hankering for something softer but have failed to find anything in this size. 70A does nothing at all to reduce noise. 3mm may come as a shock; from searching I only see max 3/32" or 2.5mm in group buy threads. But it halts travel almost immediately after actuation on my keyboard (Filco w/ MX Browns) which I rather like. You might say that I'm after a "mechanical scissor" switch, one with laptop-like travel but lighter to press and durable.
So I turn to you guys. How might I go about acquiring a softer set of rings?
Offline Photoelectric
Re: O-rings of unusual size
« Reply #1 on: Sat, 22 June 2013, 17:33:34 »
From personal experience, I really like 50A black o-rings from Amazon.com in terms of dampening the bottoming out sound and having a small bit of travel reduction.  Had great results with them with MX Browns on my first keyboard.  I don't use o-rings on my current keyboard with MX Browns--really like the full travel distance on my Ducky.
http://www.amazon.com/dp/B0051XWXCE/ref=biss_dp_t_asn
Offline Cataphract
« Reply #2 on: Sat, 22 June 2013, 23:30:47 »
Ah, I'm sorry but 3mm is almost twice as thick as those 50A 1/16" rings. I guess I could try stacking them though...
Would you happen to know of a 40A or softer ring that size? I can hardly find 40A at all from online outlets, let alone in keystem size.
« Reply #3 on: Sat, 22 June 2013, 23:35:40 »
Stacking them would prevent your keycaps from fitting on properly.  I would still give them a try at some point.  $8.25 is fairly cheap vs. other o-rings (like from WASD).  I've tried IMSTO's silicone o-rings, which are probably like 40A, and did not like either size.  The large fat size, which is something like 2.5mm thick, actually doesn't help with bottoming out noise because the inner thickness is not enough. The o-ring gets thick too far out from the center.  They are good for some very specific keys, but I'd not advise them for standard OEM keys with crossbar support.
« Last Edit: Sat, 22 June 2013, 23:37:18 by Photoelectric »
Offline Cataphract
« Reply #4 on: Sat, 22 June 2013, 23:46:18 »
So 3mm thick 30-50A rings would have negligible effect on noise versus 70A? If so then I'll just stick with my loud key slapping.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #5 on: Sat, 22 June 2013, 23:52:13 »
poop I'm waiting on these from IMSTO :(
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
« Reply #6 on: Sun, 23 June 2013, 00:08:50 »
Well, maybe they'll be okay for your caps.
Offline Topre
« Reply #7 on: Sun, 23 June 2013, 01:11:02 »
How do Cherry switches even work with o-rings thicker than 2mm? I thought the actuation point was at 2mm and if you had a thicker o-ring then shouldn't the contact points be unable to contact?
Offline Johan
« Reply #8 on: Mon, 24 June 2013, 03:50:19 »
Its rubber so it should squish to a point where it registers.
Uh, stuff.
« Reply #9 on: Mon, 24 June 2013, 08:14:41 »
My daughter had a bag of dental rubber bands left over from her braces.
To my fingertips, these feel thinner and softer than any of the typical O-rings I have tried.
- D Trump 2026-10-24
Offline Topre
« Reply #10 on: Mon, 24 June 2013, 21:26:09 »
Yes o-rings are silicone, but most silicone does not compress from 3mm to less than 2mm. The thickest o-rings that WASD Keyboards sell are 0.4mm, which are more 2.6mm thinner than 3mm o-rings.
« Reply #11 on: Mon, 24 June 2013, 21:31:54 »
I don't think you have your units or numbers correct.
Offline Topre
« Reply #12 on: Tue, 25 June 2013, 01:55:30 »
I also didn't think they were only 0.4mm thick, but I highly doubt they are thicker than 2mm. I'm getting these numbers straight from WASD Keyboard's site. A 0.4mm reduction should mean a 0.4mm o-ring.
Unless if you slam on your keycaps, I don't understand how keys will register with 3mm thick o-rings.
« Last Edit: Tue, 25 June 2013, 02:00:57 by Topre »
« Reply #13 on: Tue, 25 June 2013, 10:03:49 »
The O-rings are donut-shaped.  It means that they have a varying thickness profile.  If you imagine their cross-section as a circle, going from the keycap stem outwards, their thickness will grow and then diminish.  The location of the maximum thickness is determined by 1. inner diameter of the "donut hole" and 2. the diameter of the "donut's" cross-section.
The underside of the keycaps hits the bottom of the switch stem to make the bottoming out noise.  The larger an o-ring is, the more exposed and less padded the inner circle becomes.  The O-ring of 1.2mm maximum thickness can reduce travel distance only by a fraction of that thickness, because of the thickness decrease toward the keycap stem.
 I think an ideal o-ring would have a uniform square / rectangular cross-section to work with all kinds of keycaps.  But then there exist landing pads, so maybe those are what the OP really needs.
Offline Topre
« Reply #14 on: Tue, 25 June 2013, 12:32:18 »
Actually I figured out why, I had translucent low profile keycaps that would touch the top of the switch casing. With regular keycaps there is more than just 1mm of room between the top of the casing and the keycap itself, not including the stem. That means 3mm o-rings would not have worked for my low profile keycaps, but would have been fine for my regular keycaps.
