Author Topic: IBM Model F XT Pinout  (Read 3646 times)
Offline cheath94
« on: Wed, 26 June 2013, 02:15:45 »
I have a ibm model f xt keyboard that didnt come with a cable, is there anyone that can tell the pinout on the 14 pin connector on the keyboard controller?
Re: IBM Model F XT Pinout
« Reply #1 on: Wed, 26 June 2013, 13:12:16 »
I don't have it on me, but when I get home, I'll open up my XT and check for you if you don't have your answer before then.
Offline mich
« Reply #2 on: Thu, 27 June 2013, 05:39:35 »
IDK either, but
- whatever is connected to the case is ground
- whatever is connected to a capacitor connected on the other side to ground is +5V
- the remaining two can we swapped without damage (i.e. you have to check two combinations)
Offline Soarer
« Reply #3 on: Thu, 27 June 2013, 05:56:01 »
This should help. All of the connections are on the top row of pins.
Offline cheath94
« Reply #4 on: Fri, 28 June 2013, 12:42:35 »
Thanks guys for the replys, before i came back on here to check i did what mich said. I knew what the ground and 5v lines were so i picked the other 2 for the data and clock.
