Author Topic: Broken cherry switch :(  (Read 2460 times)
Offline TimIsABat
  • MX Clears are life
    • Instagram
« on: Wed, 26 June 2013, 18:25:51 »
I think the switch on the W key on my poker X is broken...
It with either not type sometimes or it would it would multiply. I am typing this on my FC660M...
I am uber upset right now cause the poker was becoming my favorite board.
The W on this keyboard is working just fine but not on the Poker X
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Re: Broken cherry switch :(
« Reply #1 on: Wed, 26 June 2013, 18:31:05 »
Sounds like a faulty switch. Pokers are PCB mounted so it shouldn't be too hard to fix, just get a replacement switch.
Offline insilica
  • Keyboard Geeza
« Reply #2 on: Wed, 26 June 2013, 18:31:13 »
Replace it :rolleyes:
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
« Reply #3 on: Wed, 26 June 2013, 23:58:32 »
Desolder it and solder a new one on.  If you can't do that, get someone to do it for you.  It's a quick and easy fix.
Offline TimIsABat
    • Instagram
« Reply #4 on: Thu, 27 June 2013, 14:25:54 »
Looks like I gotta learn how to solder
Offline Thimplum
  • Master of all Ponies
« Reply #5 on: Thu, 27 June 2013, 14:35:44 »
Yip. But, for something that simple, you'll find it to be pretty trivial if you've got the equipment.
TP4 FOR ADMIN 2013
Offline TimIsABat
    • Instagram
« Reply #6 on: Thu, 27 June 2013, 14:49:18 »
True. I gotta find someone who has a solder iron. I also have to buy a new switch. Anyone know where I can get a good price on cherry mx switches?
« Reply #7 on: Thu, 27 June 2013, 15:05:40 »
Mouser, Digikey, the switch tester at WASD, they'll all probably cost about the same with shipping.
Offline TimIsABat
    • Instagram
« Reply #8 on: Thu, 27 June 2013, 15:23:45 »
The switch tester uses plate mounted instead of pcb mounted switches but i will check the other two
