Author Topic: Key Size In Ducky Shine 2 vs Razer BlackWidow?  (Read 4688 times)
Offline DuckNorris
« on: Fri, 28 June 2013, 00:55:42 »
Hello There,
   I have a question today regarding key sizes on certain keyboards. I am currently leaning for my 3rd mechanical keyboard and I am very interested in the Ducky Shine 2. However, due to a previous purchase when I bought a Corsair K70, I realized something odd, the keys in the K70 felt smaller to me in size, and it was hard for me to type on it (also the space bar was small). I wasn't sure if other keyboards were like this. I currently like the size keys in my Razer Black Widow, and was wondering if those of you with a Ducky Shine 2, have ever tried a black widow and saw that the keys were same sizes?
This may sound like an odd question but ever since that K70 that felt smaller to me, I have been keeping that in mind regarding keys.
Thank you for your time!
Re: Key Size In Ducky Shine 2 vs Razer BlackWidow?
« Reply #1 on: Fri, 28 June 2013, 00:57:55 »
Welcome to Geekhack!
Both my Ducky Shines have "standard" sized keycaps.
99% of Cherry MX keyboards would also have standard sized keycaps.
Perhaps the K70 keycaps were more tapered at the top, so the finger area was less?
Offline DuckNorris
« Reply #2 on: Fri, 28 June 2013, 01:08:41 »
Yeah it did felt that way indeed, and to me it was extremely awkward to type on that keyboard ,had to return it. So I was wondering if the Ducky Shine are tapered or not. I really hope not since I really want to buy one. I have a lot of finger area on that Razer BlackWidow, why I like it. However, I want to try the quality on the Ducky Shine and different led modes it has and customizations.
« Reply #3 on: Fri, 28 June 2013, 01:22:21 »
General consensus is that the Ducky has a much higher quality than the BWU.
You can always replace the keycaps, BYW, Ducky or otherwise :)
« Reply #4 on: Fri, 28 June 2013, 01:39:38 »
Ducky has standard key sizing.
As rowdy mentioned you can always replace your keycaps, however on the Black Widow it uses weird bottom modifiers/spacebar, and another thing to note is that the F-row spacing is compressed. BWU is far from standard
Offline ksm123
« Reply #5 on: Fri, 28 June 2013, 03:44:04 »
Razer BW modifiers are not wreid, there are pretty standard:
1,5 Ctrl
1 WinKey
1,5 Alt
6,25 Space (I'm not sure of this one)
1,5 AltGr
1 Fn
1 Menu
1,5 Ctrl
I'm managed to use 20+ years old keycaps on BW (minus Space, Enter, BackSlash/Pipe and narrow x1 modifiers)
Offline Topre
« Reply #6 on: Fri, 28 June 2013, 03:50:16 »
1,5 Ctrl
1 WinKey
1,5 Alt
1,5 AltGr
1 Fn
1 Menu
1,5 Ctrl
The spacebar is 6x on the BlackWidow.
Offline DuckNorris
« Reply #7 on: Fri, 28 June 2013, 21:43:47 »
Thanks plenty for your input guys, I guess I might go ahead and purchase the ducky shine 2 and hopefully it is comfortable to type in.
« Reply #8 on: Fri, 28 June 2013, 23:54:03 »
Or if you are not in a particular hurry, maybe wait for a Shine 3.
Offline DuckNorris
« Reply #9 on: Sat, 29 June 2013, 07:23:29 »
Oh wow, thanks a lot for the heads up . I will wait for the Shine 3 instead. Also though, anyone knows a estimate of when it will  be released for purchase?
Offline nightsnack
« Reply #10 on: Sun, 30 June 2013, 05:06:30 »
It'll probably be August if you are in the US. Taiwan should be slightly earlier.
