Author Topic: Ducky 108 PBT Keycaps will fit Filco Majestouch 2?  (Read 6554 times)
Offline peter79
« on: Fri, 28 June 2013, 01:38:53 »
Hi all, I would like to know whether Ducky 108 PBT Keycaps will fit my Filco Majestouch 2 104 Keycaps.
The difference between 108 and 104 keycaps, is only 4 additional keycaps which is not usable for Filco keyboard right?
Will the rest of 104 keycaps will fit on Filco? I would like to buy the 104 keycaps, but it's only available 108 keycaps at local shops.
Any infos and comments are very appreciated, thanks  :)
Offline Photoelectric
Re: Ducky 108 PBT Keycaps will fit Filco Majestouch 2?
« Reply #1 on: Fri, 28 June 2013, 01:42:09 »
Yes, they will fit fine.  No comments as you are correct on all counts.
« Reply #2 on: Fri, 28 June 2013, 02:02:34 »
What Photoelectric said, plus nice Filco :)
