Author Topic: SteelSeries Ikari Opinions?  (Read 4917 times)
Offline Quardah
    • DeliTech
« on: Fri, 28 June 2013, 11:12:16 »
Hello!
My old mouse is getting pretty crappy (Double clicking and sometimes releases from an hold click) now and i'm looking something new (i have a DeathAdder right now).
I was checking the Ikari and i was wondering if it would be worth it to get one but since it's a pretty old model i don't really know what to expect.
Anyone can give me his opinion please?
Thanks.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline fuzzyx3000
Re: SteelSeries Ikari Opinions?
« Reply #1 on: Fri, 28 June 2013, 12:26:09 »
I used the ikari right after using the death adder and liked it much better ergonomically compared to the death adder, but the rubberized surface seemed to get dirty pretty easily and got harder and harder to clean after a while. Eventually I got the Mionix Naos 3200 and the ergonomics between the two were very similar but I liked the coating a lot more, and I think it's probably more economical nowadays because I think ikaris are harder to come by.
Offline Quardah
    • DeliTech
« Reply #2 on: Fri, 28 June 2013, 13:01:25 »
I might get a deal from someone i know, an Ikari for 40$. Is it worth it?
Poker II - Brown MX
Offline guilleguillaume
« Reply #3 on: Sat, 29 June 2013, 13:49:46 »
The Steelseries Ikari is by far the most comfortable palm grip mouse I've ever had. I don't use it today because it had frequent disconnections (I think this is the most common problem this mouse had in the past) and I moved on to smaller mice.
Offline Quardah
    • DeliTech
« Reply #4 on: Tue, 02 July 2013, 10:09:41 »
Thanks for the replies.
I have made my deal and i am receiving it pretty soon now. I hope i'll enjoy.
I'll do a follow up soon about my appreciation.
R.I.P. DeathAdder :(
Poker II - Brown MX
Offline Grim Fandango
« Reply #5 on: Tue, 02 July 2013, 10:37:47 »
I think it all depends on how well the shape works for you. I know that the Ikari optical is pretty popular among Steelseries sponored pro teams.
Offline Quardah
    • DeliTech
« Reply #6 on: Tue, 02 July 2013, 13:01:48 »
The one i got on deal is Laser not optical. Any clue if it's any better?
I guess laser is best since it's newer technology but i am not sure.
Poker II - Brown MX
Offline davkol
  •  Post Editing Timeout
« Reply #7 on: Tue, 02 July 2013, 14:54:21 »
Marketing team did their job well.
Offline mauri
« Reply #8 on: Tue, 02 July 2013, 15:24:25 »
Great mouse, had the laser one, actually 4 or 5. Doubt the laser is more accurate than the optical, quite the contrary, depending of course whether you use high or low sensitivity. Great for high sensitivity, very precise but I think that could be said of every laser mice.
Here's a size comparison; Ikari - DA - Ec2
« Last Edit: Tue, 02 July 2013, 15:41:29 by mauri »
I AM BABAR KING OF THE ELEPHANTS
Offline Quardah
    • DeliTech
« Reply #9 on: Tue, 02 July 2013, 17:19:39 »
Thanks for the comparision.
Looking a little info Laser gets the edge with higher DPI even if i won't use them (i'm a low dpi player). Still, laser works on glass and that's pretty cool.
For 40$ i mean the optical is more expensive than that. Why would i settle for less?
Poker II - Brown MX
Offline BliTzKiN
« Reply #10 on: Mon, 08 July 2013, 23:30:35 »
I don't think you'll regret your purchase. My friend used to own one and comparing it with my deathadder, Xai and lacheisis, I can safely say his Ikari was by far the MOST comfortable mouse to use. Apart from the weird shape though, tracking is pretty good as well.
Offline Quardah
    • DeliTech
« Reply #11 on: Tue, 09 July 2013, 07:29:37 »
I've had it for about 3 days now and i'd say it's a never look back from the DeathAdder really. While the DeathAdder was pretty damn cool i think the Lazur Ikari is way better in every way. The straightner driver is just a blessing.
Poker II - Brown MX
