Author Topic: Ergo-clear lube life  (Read 3819 times)
Offline grips
« on: Fri, 28 June 2013, 11:27:55 »
I have a little Krytox lube set that I picked up from limmy a few days back. I plan to mod some clear switches into ergo-clears. Does anyone have any experience with how long the lube effect lasts, in general, for these switches? Will I need to lube them again in a year or two?
Offline WhiteFireDragon
    • youtube
Re: Ergo-clear lube life
« Reply #1 on: Fri, 28 June 2013, 16:11:53 »
Krytox should last for the lifetime of the switches, no need to relube.
Offline Photoelectric
« Reply #2 on: Fri, 28 June 2013, 16:59:32 »
Took apart my brand new MX Clears today (only a couple of the switches) and noticed that they do come pre-lubricated where the front (top?) protruding slider piece is--but not along the left and right sides.  There was a noticeable amount of wet shine from the pre-applied lubricant.  Any idea what that lubricant is and how it's best to cleanly remove it to re-lube fully with Krytox stuff?
    • youtube
« Reply #3 on: Fri, 28 June 2013, 17:02:05 »
Some switches do come pre-lubed, but never on the rails of the stem or housing. It looks "wet", but they use some kind of grease, no oil.
Offline grips
« Reply #4 on: Fri, 28 June 2013, 18:16:20 »
Thank you
Offline quickcrx702
  • Ready to bomb with Vietnam tatted on my back
« Reply #5 on: Sun, 30 June 2013, 01:54:08 »
Can you use motor oil to lube the switches?  I'm half joking, half serious, but I really would like to know because I have a bunch in the garage.
Offline biochem
« Reply #6 on: Mon, 01 July 2013, 08:42:53 »
Motor oil is alkaline which means that it can corrode the metal springs and contacts in the switch. Kyrtox lubricants are inert and thus are a much better choice.
Filco MJ2 tenkeyless (blues)
Heatware
