Author Topic: Alternative Return Key  (Read 2328 times)
Offline Classic
« on: Sat, 29 June 2013, 09:41:01 »
Will a alternative return key work on a Filco Ninja Keyboard?
Offline SeriouSSpotS
  • 60% is love, 60% is life
Re: Alternative Return Key
« Reply #1 on: Sat, 29 June 2013, 10:07:23 »
What do mean by alternative? could you give some more info (links/pics etc.)?
Offline Classic
« Reply #2 on: Sat, 29 June 2013, 10:12:12 »
I would like to use the shape key as pictured above on my Filco Ninja keyboard.  Is it possible to modify the board etc. to make the above key work.  I really like how the return key pictured above looks.
« Reply #3 on: Sat, 29 June 2013, 10:13:14 »
That's an ISO enter and you'd have to mod the plate and PCB in order to get that to work. It's probably not worth the time/effort to do it if you have ANSI layout already.
