Author Topic: Will the realforce topre keycaps from EK work on a HHKB?  (Read 2693 times)
Offline acantha
  • Aure Entuluva
« on: Sun, 30 June 2013, 03:15:06 »
hope this hasn't been answered elsewhere and my search-fu just completely failed me.
i'm a proud new owner of a HHKB Pro 2 (black lettered) and i'm looking to pickup some colored keycaps for it. From what i can discern, elite keyboards is the only place that sells topre keycaps, but the only ones they have explicitly for the hhkb are the standard white and black lettered/unlettered. But they do have realforce keycap sets. Looking at pictures of the realforce, i imagine some of the keys won't fit, but has anyone tried it? do enough fit to make it worth buying?
All the Happy Hacking Things
Offline acantha
  • Aure Entuluva
Re: Will the realforce topre keycaps from EK work on a HHKB?
« Reply #1 on: Sun, 30 June 2013, 03:43:35 »
i would find the answer to my own question as soon as i post about it. Apparently they will fit. good to know!
Offline longweight
  • philanthropist
« Reply #2 on: Sun, 30 June 2013, 03:47:02 »
Except for the short right shift, you have to use the spare capslock key with the LED window which ruins the look IMO.
