Author Topic: Can anyone tell what board this used to be?  (Read 2910 times)
« on: Mon, 01 July 2013, 02:06:00 »
27033-0
27035-1
Offline YoungMichael88
  • HHKB Wannabe
Re: Can anyone tell what board this used to be?
« Reply #1 on: Mon, 01 July 2013, 02:57:45 »
Wow. That looks like it went through something traumatic!
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Mon, 01 July 2013, 03:22:01 »
Time to play guess the movie! Uh... The Matrix?
I've seen that switch type before yes, but the name completely escapes me now.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #3 on: Mon, 01 July 2013, 03:39:21 »
Yeah the switch looks so familiar at first I thought it was a BS board that had been modified, but the spring doesn't buckle when pressed.
I would be genuinely impressed if someone knew what movie this was from.  :cool:
Offline rootwyrm
    • My Website!
« Reply #4 on: Mon, 01 July 2013, 03:59:33 »
No, it's not buckling spring. It's a linear switch with a spring over the post - though I don't remember if the spring is stock or special effects. I wanted to say it was a Honeywell Hall Effect, but the shape is inversed. (Square post sticking up, rather than a square hole in the post.)
Here's what a Honeywell looks like.
And it's not The Matrix? Huh. Now my curiosity is piqued.
Ah right. Matrix was an old Apple PowerBook keyboard.
« Reply #5 on: Mon, 01 July 2013, 11:13:01 »
I think that it could be some kind of foam-and-foil key switch, or similar hybrid design. The square keycap mount reminds me of Mitsumi switches.
Offline 0100010
  • Not Sure
« Reply #6 on: Mon, 01 July 2013, 11:32:45 »
Couldn't tell you what board - but I do want to know what movie that is from.
« Reply #7 on: Mon, 01 July 2013, 11:38:31 »
Looks like a keytronic to me. You can see some of the springs have been removed. It's got the same individual switches, and the stems looks limilar enough to me.
Offline asura
  • not a duck
« Reply #8 on: Mon, 01 July 2013, 13:35:02 »
I found this...
And this...
Seriously though, what film?
Offline Techno Trousers
  • ʘ_ಠ
« Reply #9 on: Mon, 01 July 2013, 13:56:10 »
Looks like something that belongs in the the universe of the Aliens movies. I don't recall anyone using a keyboard like that though.
Offline Trent
« Reply #10 on: Mon, 01 July 2013, 13:59:36 »
Looks like my Radio shack keyboard
Quote from: Trent
I hate fun
IBM Model M | IBM Model M SSK | FK-2000 | FK-8000 | FK-9000 | Fujitsu Peerless | Zenith Data Systems (Yellow ALPS!) | AEK
« Reply #11 on: Mon, 01 July 2013, 16:59:11 »
OK OK, it's from a movie called Hardware. Watch the first 40mins they are amazing, the rest not so much. It's on Netflix if you wanna check it out.
« Last Edit: Mon, 01 July 2013, 17:00:44 by noisyturtle »
Offline rootwyrm
    • My Website!
« Reply #12 on: Mon, 01 July 2013, 17:24:45 »
It's not the Westinghouse - there's cutouts on the edges of the Westinghouse. There are none on the SFX keyboard.
It's also not a Trash-80 Model 12 - those are inverse Cherry-style. (Cross cutouts.) It's not a Trash-80 Model III either as we found here. I thought it was an Osborne/1 keyboard but unfortunately it is not.
I may have to watch that movie sometime.
« Reply #13 on: Mon, 01 July 2013, 17:40:11 »
It may be something from some control console that's relatively unknown outside of some industrial use. I would guess a European company based on where it was filmed, maybe from a shutdown factory or something.
