Author Topic: Cherry G83-6105 - keycap... MX compatible?  (Read 3750 times)
Offline ShivaYash
« on: Mon, 01 July 2013, 04:39:55 »
Hello,
A quick question that no doubt someone here will be able to answer.
Will the keycaps from this Cherry G83-6105 fit their MX switches?
Many thanks,
SY
IBM Model M SSK, HHKB Pro 2 BT and Realforce 104U HiPro
Offline calavera
Re: Cherry G83-6105 - keycap... MX compatible?
« Reply #1 on: Mon, 01 July 2013, 05:13:11 »
G83 = rubber dome.
so nope.
Offline ShivaYash
« Reply #2 on: Mon, 01 July 2013, 05:20:32 »
Ah I see. I was under the impression 'some' other Cherry switch keycaps were compatible with the MX.
Many thanks,
Offline damorgue
    • Personal portfolio
« Reply #3 on: Mon, 01 July 2013, 06:43:05 »
Key caps from G81 (Cherry MY switch) keyboards are compatible with G80 (Cherry MX switches). G83 aren't.
