Author Topic: Where can I buy a full set of caps for my HHKB pro 2?  (Read 2735 times)
« on: Mon, 01 July 2013, 08:05:09 »
I looked at EK, but I don't want to order 2 sets because of the short shift.
I should explain I love very colorful keycaps (my qfr is unicorn vomit) so the more colorful the better.
The best thing would be a full set, but if you can only show me a partial one, that's fine too. I can make it work.
Offline insilica
  • Keyboard Geeza
Re: Where can I buy a full set of caps for my HHKB pro 2?
« Reply #1 on: Mon, 01 July 2013, 08:08:18 »
Did you scroll right down to the bottom?
http://elitekeyboards.com/products.php?sub=access,toprekeys
 :rolleyes:
If you are after color, well I haven't heard of anyone.
There are people with ClickClack blanks on their boards, or using RF caps, but as you quite rightly pointed out the short shift is a problem so you will need two RF sets.
« Last Edit: Mon, 01 July 2013, 08:11:03 by insilica »
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline Dgsbllx
« Reply #2 on: Mon, 01 July 2013, 08:12:08 »
Yup two sets is the only way. I'm slowly adding more color with clacks, ordered a yellow set from here (http://geekhack.org/index.php?topic=43270.0) and ordered an orange wasd and few blank reds from EK. Missed out of the enter keys that EK use to have  :(
Offline insilica
  • Keyboard Geeza
« Reply #3 on: Mon, 01 July 2013, 08:25:55 »
They do have modifier sets including the left and right shift in orange and yellow:
http://elitekeyboards.com/products.php?sub=access,toprekeys&pid=tmod_org
http://elitekeyboards.com/products.php?sub=access,toprekeys&pid=tmod_yel
« Reply #4 on: Mon, 01 July 2013, 09:49:31 »
That sucks. Maybe I'll buy a replacement set (in white, my Hhkb is black), then a set of yellow from EK. Maybe get the replacement set in black with the orange set. That might look slick.
Anyway, thanks for the help.
