Author Topic: Where to get/what to use for switch housing pullers?  (Read 2351 times)
« on: Wed, 03 July 2013, 23:25:11 »
Doing some modding. Tired of using ghetto-ass switch housing separators and potentially damaging switches. Where can I find dedicated housing separators?
Re: Where to get/what to use for switch housing pullers?
« Reply #1 on: Wed, 03 July 2013, 23:26:08 »
If you check the OP of the simple questions simple answers thread, there's some suggestions. And other ones besides The_Beast's switch tool
« Reply #2 on: Thu, 04 July 2013, 00:29:37 »
Exactly what CPTBadAss said.  By far, my favorite are modded binder clips.  I have The_Beast's switch tool, but I find myself going back to the binder clips more often.
Offline MKULTRA
  • telling it how it is
« Reply #3 on: Thu, 04 July 2013, 01:09:25 »
I use a little screwdriver and just pop the tabs up.
Offline tipo33
  • "Ski"
« Reply #4 on: Thu, 04 July 2013, 01:16:36 »
I use a pocketknife with a fine tip.
KM4COL    R.I.P.  SmallFry
Offline actionbastard
« Reply #5 on: Thu, 04 July 2013, 01:21:29 »
Can you use the binder clip method on plate mounted switches?
« Reply #6 on: Thu, 04 July 2013, 01:27:52 »
You can't open a plate mounted switch without desoldering it and popping it out of the plate unless you have a custom plate that allows you to do so.
« Reply #7 on: Thu, 04 July 2013, 01:33:55 »
Alright so PCB mounted are the kind you can open, got it.
« Reply #8 on: Thu, 04 July 2013, 01:36:32 »
If your PCB mounted switches have LEDs, you'll still need to desolder the LEDs.
Offline bazemk1979
« Reply #9 on: Thu, 04 July 2013, 02:16:29 »
and and when he is done desoldering he better mod the top switch cover so he don't have to deal again in near future, stock leds are fine and they don't need modding since they don't have that pad around I hate the most....
Offline gnubag
« Reply #10 on: Thu, 04 July 2013, 02:18:12 »
this. If you make them correctly they are as good as the beast switch opener
http://www1.kbdmania.net/xe/tipandtech/3520312
