Author Topic: Noppoo Choc-84 Mini ASCII code input issue  (Read 2076 times)
Offline notrox
« on: Fri, 05 July 2013, 11:26:07 »
Hello,
I just got in a Noppoo Choc-84 mini keyboard and was doing some testing with it and I am having an issue trying to produce ASCII characters via number pad alt code. I have number lock turned on and have tried using right alt, left alt, right alt + fn, left alt + fn then tried inputting the four digit alt code with no luck. I am not sure what else to try from here out thanks!
- notrox
Offline notrox
Re: Noppoo Choc-84 Mini ASCII code input issue
« Reply #1 on: Sun, 07 July 2013, 16:40:15 »
bump
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Sun, 07 July 2013, 17:04:33 »
I don't think it's possible in my GNU/Linux DE, so I can't test it. I never used it in MS Windows either. If you can reproduce all required steps, maybe I could try it.
Offline notrox
« Reply #3 on: Sun, 07 July 2013, 17:45:01 »
I have done testing on Windows 7 along with OpenBSD 5.2. I haven't had any luck in either OS. I have not tried any distribution of Linux yet, the search continues.
