Author Topic: blank key caps for blackwidow  (Read 6188 times)
Offline Skyway
« on: Sat, 06 July 2013, 23:43:35 »
Hi all. I was looking for advice regarding getting key caps for the blackwidow and I stumbled across this forum and it seems pretty cool.  Basically I'm looking for blank key caps to replace all the keys on my blackwidow (normal version, not tournament or ultimate, its the version with the glossy finish).  Anyways I've read around this forum and noticed something about the bottom row of keys not being replaceable or something?  Could someone clarify that for me?  Also where is the best place to buy a set of blank caps for my whole keyboard?
Thanks in advance everyone!
Offline Rule16
  • R.I.P. SmallFry
Re: blank key caps for blackwidow
« Reply #1 on: Sat, 06 July 2013, 23:53:28 »
It would probably be more worth it to invest in a better quality keyboard instead, since that one is likely to break very quickly. Good alternatives are Ducky if you need a numberpad, CoolerMaster Quickfire Rapid, or a Poker II if you only need the main row of keys to be physical.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Skyway
« Reply #2 on: Sun, 07 July 2013, 00:11:25 »
haha i'm totally fine with my blackwidow.  I'm just looking for blank key caps cause I want a different look on my keyboard.  Thanks for the suggestion anyways
Offline badcop
  • thorpe thocking master race
« Reply #3 on: Sun, 07 July 2013, 00:23:00 »
its not that they aren't replaceable, its that you're going to have a hard time finding the right size.  normal winkey keyboards use the following sizes from left to right
1.25 - 1.25 - 1.25 - 6.25 - 1.25 - 1.25 - 1.25 - 1.25
your blackwidow uses (from what i can see in pictures at least.  someone please correct me if im wrong)
1.5 - 1 - 1.5 - 6.25  - 1.5 - 1 - 1 - 1.5
Most of the sets you're going to find, use 1.25 modifers and thats where you have a problem.  On top of that, you have the macro keys with different profiles on each row.  You're going to have to frankenstein a couple of sets of keys to get a full set for your blackwidow.
« Reply #4 on: Sun, 07 July 2013, 00:30:40 »
Here is a compatibility chart for keycaps: http://www.wasdkeyboards.com/keycap-compatibility
Blackwidow doesn't come out on top, unfortunately.
Offline gnubag
« Reply #5 on: Sun, 07 July 2013, 01:51:46 »
spacebar of the blackwidow is a 6u btw.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Sun, 07 July 2013, 09:56:55 »
that's crap...........
i've had mine for over a 1 year and a half- nothing broke and it is still a tank, hasn't skipped a beat. agreed the keycaps are a real pain, but not impossible if you are patient.
agreed other boards are a better investment if your intent is to switch caps- bwu will be $ to switch out.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline badcop
« Reply #7 on: Sun, 07 July 2013, 10:35:00 »
ahh thats for the heads up.
Offline RabRhee
« Reply #8 on: Sun, 07 July 2013, 12:22:26 »
Some places do have modifiers for that layout, but not seen a blank set on my travels. QWERkeys does an Ansi and ISO version for that layout, they refer to it as the 1x1 windows key version. (With a purple FN key as a separate buy).
http://www.qwerkeys.co.uk/shop/index.php?route=product/product&path=59_72&product_id=76
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #9 on: Wed, 10 July 2013, 10:29:19 »
I never understood the hate on the Blackwidow line. Regardless that the price is almost into Filco territory, my OG BWU worked fine for the year and a half that I had it, and still works fine for the friend I sold it to. Only gripe I ever had with it is the glossy plastic shell. When I had my BWU, I replaced just the alphas with an alpha kit from WASDKeyboards.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Wed, 10 July 2013, 10:48:59 »
Maybe DSA blanks from SP would be a good option for you. Looks like they just added some pretty good price sets, then buy some a la carte for the 1.5 and extra 1 unit keys you need for the bottom row and macros. You will probably still be stuck with the stock spacebar though.
Offline Rule16
  • R.I.P. SmallFry
« Reply #11 on: Sun, 14 July 2013, 23:23:25 »
Do you know how thick those are lysol? I might have to get those...
Dvorak Only Zone
« Reply #12 on: Mon, 15 July 2013, 00:13:19 »
DSA is like almost 2x as thick as their DCS keys.
Offline Rule16
  • R.I.P. SmallFry
« Reply #13 on: Mon, 15 July 2013, 17:29:51 »
I dont have any of their DCS keys but from the pictures it looks like they're about 1/4 of imsto thickness, correct?
Dvorak Only Zone
Offline SkyCorrigan
  • Formerly known as "sloth_mc"
« Reply #14 on: Sun, 21 July 2013, 00:13:17 »
Your first problem is that you have a BW
Sloth with that QWERTY know-how
