Author Topic: Red/black Switch TKL Keyboard needed  (Read 2910 times)
Offline jd4311
« on: Sun, 07 July 2013, 22:00:09 »
Hey guys, I am looking for a red/black switch TKL keyboard recommendations. My only special requirement is that its TKL and 100% compatiblitable with replacement caps from WASD keyboards, (I have a theme in mind). I feel that my blacks on the steelseries 6gV2 are a little to heavy to use so I'm inclined to try the reds. I searched for ducky and only really found the shine.. but I don't need a backlit or want backlit. I found the majestouch 2 and majestouch 2 ninja which are somewhat expensive, then I found some leopolds and noppo's but I really don't know whats good and whats not.
If nobody can recommend a keyboard cheaper than the majestouch 2 that has all easily found keycaps/standard keycaps so i can get a whole set then I'll probably just get that majestouch 2
Thanks.
Offline gnubag
Re: Red/black Switch TKL Keyboard needed
« Reply #1 on: Sun, 07 July 2013, 22:08:08 »
coolermaster quickfire rapid.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #2 on: Sun, 07 July 2013, 22:39:19 »
Yep, the QFR is exactly what you are looking for.
« Reply #3 on: Sun, 07 July 2013, 22:40:31 »
QFR +1
Or KeyCool (older ones had a non-standard space bar, but newer ones seem to have a standard space bar).
I gave one of each - both good boards :)
Offline jd4311
« Reply #4 on: Sun, 07 July 2013, 23:09:33 »
Blah, I should of mentioned I really don't like the CM ones due to the fact that there branding is everywhere on it. I did find this "stealth model" I guess I could probably go with this as its not as exessive as the other models.
http://www.coolermaster-usa.com/product.php?product_id=10035
The only thing is i don't care for the LEDS, if i buy keycaps that don't have holes for leds will it still shine slightly under the key to the point of it being noticeable?
Offline PointyFox
« Reply #5 on: Sun, 07 July 2013, 23:12:42 »
Too heavy?  They're lighter than most rubber domes, and even little kids use those.  :))
Oh, and I'll sell you my Filco Multicam with MX blacks for $130 shipped if you're interested in having a nice keyboard and developing a firm handshake.  I want to try out 60% boards.  :p
« Last Edit: Sun, 07 July 2013, 23:25:44 by PointyFox »
Offline jd4311
« Reply #6 on: Mon, 08 July 2013, 00:02:07 »
no thanks for a camo board, any other suggestions
Offline PointyFox
« Reply #7 on: Mon, 08 July 2013, 00:03:25 »
No.  Eveyone will recommend the QFR, including me.
Offline daerid
    • Rossipedia
« Reply #8 on: Mon, 08 July 2013, 00:19:37 »
The newer revs of the QFR are unbranded.
« Reply #9 on: Mon, 08 July 2013, 00:28:04 »
And you can get an unbranded case top.
Offline smknjoe
« Reply #10 on: Mon, 08 July 2013, 00:35:21 »
I just looked the new ones up. Wow, much better looking than the original. Still basically a Filco for half the price!
I have a Ducky 1087, but why get the Ducky when the new QFRs look so nice and are better build quality?
SSKs for everyone!
« Reply #11 on: Mon, 08 July 2013, 00:44:11 »
Ducky is very well built too.
You will often find Ducky recommended if someone wants backlit, and QFR is non-backlit.
Offline gnubag
« Reply #12 on: Mon, 08 July 2013, 00:48:07 »
well he mentioned the 1087 which is not too great in terms of build quality but still ok for what it is.
« Last Edit: Mon, 08 July 2013, 00:53:28 by gnubag »
Offline smknjoe
« Reply #13 on: Mon, 08 July 2013, 00:48:34 »
I should have said better perceived build quality. My Ducky is solid and has served me well, but doesn't get much use because I'm not a huge fan of browns. Does Ducky not make the standard 1087 without back lights any more?
« Last Edit: Mon, 08 July 2013, 02:00:52 by smknjoe »
SSKs for everyone!
Offline knotra
  • I ­­­♥ ⌂ ♫
« Reply #14 on: Mon, 08 July 2013, 04:10:33 »
the leopolds are not 100% compatible with WASD keycaps. its 99% compatible. the spacebar on the leopold is different than most keyboards.
i would definitely recommend the filco. great keyboard that is high quality. i have never personally tried a QFR though. so maybe they are just as good for a lower price.
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
