Author Topic: removing key caps  (Read 6894 times)
Offline poonsmjj
removing key caps
« on: Tue, 16 September 2008, 18:27:31 »
Hi everyone,
what do you guys use for removing keys from your keyboard? It's such a PITA to remove my keys from this alps keyboard... I saw some of the members in the forum having a keycap puller thing - anywhere you can buy them (and have them shipped to Canada)?? Thank you!
Offline iMav
  • geekhack creator/founder
removing key caps
« Reply #1 on: Tue, 16 September 2008, 19:00:16 »
To safely pull a keycap, use xsphat's two-paperclip method. Unbend two paperclips and make "hooks" out of them. Hook two opposite corners and pull straight up.
Offline bigpook
removing key caps
« Reply #2 on: Tue, 16 September 2008, 19:06:29 »
Or you could be reckless like me, and use a small flat blade screw driver to pry them off.
It has worked well for me so far. However, YMMV. You may be better off follwing iMavs advice.
Offline poonsmjj
removing key caps
« Reply #3 on: Tue, 16 September 2008, 19:07:33 »
darn so that's what i wasn't doing right... i only used one bent paper clip and my fingers... that eventually resorted to using a pair of scissors with tape wrapped around so i don't scratch the keys. thanks iMav
Quote from: iMav;8810
Offline iMav
removing key caps
« Reply #4 on: Tue, 16 September 2008, 19:12:41 »
Quote from: bigpook;8811
Ask ashort how well that method works.
Offline bigpook
removing key caps
« Reply #5 on: Tue, 16 September 2008, 19:25:08 »
I suppose it depends on the keys, the flat blade works well on the BS keyboards(those keyboards are tanks). I don't think I would try it on my HHKB though.....
well, then again, I am reckless, I was able to pry the right Fn key off. But the flat blade is less than optimal for that purpose. The paper clip method sounds like it would be safer.
Though on the BS keyboard the flat blade works fine for me....
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
removing key caps
« Reply #6 on: Tue, 16 September 2008, 21:38:42 »
http://hooleon.com/miva/merchant.mvc?Screen=CTGY&Category_Code=KT-P
The one on the far right is the best option. I have the one in the middle, but it isn't so good for Topre switches and it sucks for Alps.
Offline lowpoly
removing key caps
« Reply #7 on: Wed, 17 September 2008, 02:22:20 »
Alps keycaps usually have a tight fit. Wouldn't try a full keyboard without a decent keycap puller.
Offline poonsmjj
removing key caps
« Reply #8 on: Wed, 17 September 2008, 21:08:32 »
thanks for the link xsphat. shiping isn't too bad if you're in the US but it's such a killer for Canada.... $20 for a little plastic thing with wires sticking out the end?!?!!?
Quote from: xsphat;8816
Offline xsphat
  • Enlightened
removing key caps
« Reply #9 on: Wed, 17 September 2008, 23:56:53 »
Try ErgoCanada. They may be able to source you one.
