Author Topic: Realforce 87U Silent, should I sell it?  (Read 3677 times)
Offline KuhnTang
  • Game of Thrones
« on: Mon, 08 July 2013, 13:19:51 »
I just, (two days ago), got a black RF 87U (silent) keyboard in the mail.  I got this with the intent to bring it to the office, since it is silent.  My problem is that I think it is just too light for me now.  I've been typing on the 55g for a while now, so my fingers want to press harder.
Should I sell it?  Can I recoup near what I paid for it?
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: Realforce 87U Silent, should I sell it?
« Reply #1 on: Mon, 08 July 2013, 13:22:55 »
Before you sell it, use it a bit longer...
Offline insilica
  • Keyboard Geeza
« Reply #2 on: Mon, 08 July 2013, 13:50:49 »
:(. Yes definitely recommend you use it a bit longer.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
« Reply #3 on: Mon, 08 July 2013, 16:49:48 »
As suggested, try it for a bit longer.  If you're not used to Topre at all, most people suggest using it for a week or two to get used to the difference.
If, after that, you still want to sell it, you should be able to recoup most of what you paid for it (especially if it is a silenced one).
Offline AKIMbO
  • HHKBro
« Reply #4 on: Mon, 08 July 2013, 17:30:17 »
Sell it?! No way....don't you see the opportunity here KuhnTang.  Mod your 55g into a silent 55g!
| KBD75 (box reds)
Offline quickcrx702
  • Ready to bomb with Vietnam tatted on my back
« Reply #5 on: Tue, 09 July 2013, 02:04:51 »
I LOVE my 55g, but I never really felt the same love for my 45g Realforce.  You can use it longer, but if you really enjoy mashing your keys like I do, you won't get used to it.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #6 on: Tue, 09 July 2013, 08:17:03 »
+1 for that! Should be a relatively easy swap if it's another 87u.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline KuhnTang
  • Game of Thrones
« Reply #7 on: Tue, 09 July 2013, 14:27:37 »
Yeah, that's what I was thinking.  I'm still gonna give it about two weeks before I sell it though.
Has anyone tried the Hipro?
Offline longweight
  • philanthropist
« Reply #8 on: Tue, 09 July 2013, 14:30:08 »
Put the 55g domes in the silenced board, problem solved :D
Offline megaxpop
« Reply #9 on: Fri, 12 July 2013, 00:21:44 »
no no no... i think you should keep it! :D cuz i'm using this and love it!
Offline Polymer
« Reply #10 on: Fri, 12 July 2013, 01:00:31 »
Give the variable a chance..it sucks for gaming IMO but your pinky fingers will really like how it feels to type on it...You'll notice it when you go back to other keyboards and realize how much more work your pinky fingers have to do....
I still have mixed feelings about it..I wish it was a little bit heavier but overall it is a really good idea....Assuming you actually type with reasonably good form...if you're a 3 finger in each hand typer, etc...it probably won't make sense at all..
Offline insilica
  • Keyboard Geeza
« Reply #11 on: Fri, 12 July 2013, 02:57:23 »
IMO the topre silent 87u variable is the best keyboards from topre. It takes getting used to. I didn't like mine at first but over time it has really grown on me and my pinkys. The only other board I will ever consider will be a variable weight ergodox, red and browns mainly. Better yet variable topre ergodox.... one can dream of the impossible and improbable  :p
The fc660 is nice and crisp with a very pronounced thock.
For me the upper threshold is 45g for the alpha cluster.
« Last Edit: Fri, 12 July 2013, 03:00:58 by insilica »
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #12 on: Fri, 12 July 2013, 08:45:00 »
This is making me wonder if I could cleanly rob the 45g domes from my FC660C and throw them into my Type S to make it a mainly uniform 45. Hmmm.
TOO BAD FOR YOU
Offline MJ45
  • HHKB Pro
« Reply #13 on: Fri, 12 July 2013, 10:30:36 »
That should be very easily done.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #14 on: Fri, 12 July 2013, 10:33:35 »
I dug into it a bit and it appears that while the 660C has a bunch of different dome sheets, the RF's have one connected sheet, and I don't wish to cut and paste :/
TOO BAD FOR YOU
