Author Topic: What Determines A Model M Price?  (Read 2042 times)
Offline DuckNorris
« on: Wed, 10 July 2013, 12:47:43 »
Hello Guys,
   Today I was wondering after looking through ebay and seeing other websites got me curious about the price. I know SSK go on higher price since they are rare but others are not as high. Are older ones worth more? Does it depend on the label? Thanks for your input!
Offline phx
Re: What Determines A Model M Price?
« Reply #1 on: Wed, 10 July 2013, 12:50:10 »
think most people just price theirs on how clean it is, no reason to get one that's shiny and stuff, just clean it yourself.
« Reply #2 on: Wed, 10 July 2013, 12:51:17 »
It's largely rarity and condition. New In Box ones will go for more, fully functioning boards with all original caps are obviously going to be worth a little more, those with PS2 are going to be worth more than those with RJ45 in most cases, less common models like the SSK, Model M Industrial, or M15 will be worth more, and models with the less common blue label will be worth more.
« Reply #3 on: Wed, 10 July 2013, 12:52:19 »
Blind stupid luck.
Personally, I like the old ones with the heavy metal backplates, and think that the metal badges are cool.
But other people like newer ones with fresher springs.
They are easy enough to take apart and rehab, so there is less risk in buying used.
- Franklin Roosevelt 1933
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Wed, 10 July 2013, 14:52:04 »
just curious............exactly which ones have the heavier back plate? i know the 401's went for a long time.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #5 on: Wed, 10 July 2013, 15:14:27 »
The early ones. The 1390120 and 1390131 had the metal badges and went through about 1987 or so. The 1391401s ran for years, well into the Lexmark era. ISO equivalents had different numbers.
I think that the heavy back plates were generally concurrent with the wire stabilizers, up through early-mid-1989, but I don't know if there is a definitive cutoff or if different plants made changes at different times.
The yellow/gold backplates went through 1986, give or take, and were replaced by the dull gray ones. I think that these were the same except for the finish.
This is purely empirical and based on owning at least a couple from each of those years. My opinion is just that, but I suspect that you will not find more specific written records.
I am sure that someone like rootwyrm will chime in on this.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #6 on: Wed, 10 July 2013, 16:08:30 »
^ re pricing. Pretty sure drugs are involved too.
Heaviest backplate is pre-'89, there's two variants. One is gold hued, the other is unfinished steel. They're the same thickness, but the gold hue version has slightly higher hardness and looks nicer. Specific models, well, too many to list. The unfinished steel is however, the exact same thickness as the gold one within expected tolerances. The gold one just has a different treating process.
The next version is slightly thinner, still unfinished steel. Hate these so much because they're prone to rust - there's no anti-corrosion on them. At all. Usually found in '89-'92ish but they're all over the place.
Third version is the '93+. Same thickness as the '89-'92ish but IBM apparently put the anti-corrosives back in the mix, since I rarely see these with significant rust damage. Unicomp's current are the same. However, IBM relaxed tolerances and may have made some die / pressure adjustments plus tooling wear/tear.
I'd agree with fohat there's almost no chance of written records. Maybe you'd find an order for the raw materials but that's about it. Each plant seems to be different in some minor or major ways, depending, and I don't know if they made all the plates in a central location or each facility had the tooling.
I'm going back to being sick now.  :-\
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
